Kenmore electric dryer model 88042 runs but stops short beeping
Based on symptom and details, the control has detected a component failure. Since your model does not have digital display window in order to display a fault code, it will flash the four indicator lights of
Drying, Cool Down, Wrinkle Rid (Press Saver), and Clean Lint Filter will flash the number of times for the first digit of the code and the START indicator light will flash the number of times for the second digit.
Take separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting the number of times the lights flash. Example E24: The four indicator lights would flash twice indicating the 2 and the START indicator light will flash four times indicating the 4. The four indicator lights and the START indicator light
start flashing at the same time. The control will pause for 2 seconds, then repeat the code.
The failure is likely because of a faulty thermistor or because the heater is not working. It could have a broken heating element or a burnt wire connection at the control board. I would begin by accessing the thermistor and disconnecting it. The thermistor can be tested with an Ohm meter. The thermistor should measure approximately 50,000/5K Ohms at room temperature.
The heating element is located behind the drum and it can be disconnected and tested for continuity with an Ohm meter.
NOTE: Disconnect the dryer from the power supply before servicing.
