D-Link DAP-1360 Wireless N Range Extender Logo
Ramon Jacob Posted on Oct 09, 2012
Router can't detect DAP 1360 when installed about 90 meters away. UTP connectors tested okay.
Bought a DLINK router and DAP 1360 Access Point. Intention was to extend the wireless access of the internet from the router about 90 meters away. UTP connectors were configured as straight thru and were tested okay. DAP 1360 can't detect router. I prior tested the DAP 1360 near the router and it functioned well.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Oct 12, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
3915
Points
10
Have you tried turning on and off the router and AP? it would scan again...it looks like you just need to recheck connections and powers...
4 Related Answers
Anonymous
  • 104 Answers
  • Posted on May 03, 2007
SOURCE: Laptop can't find access point!
Some laptops come with a button\switch or use key combination to turn on or off the wireless(to conserve power)! Refer to your user manual for exact instructions! If that didn't solve the situation then it could be your actual wireless card within the laptop is giving trouble! regards, babb
Anonymous
  • 366 Answers
  • Posted on Jan 26, 2009
SOURCE: cannot install access point dwl 2100
Visit the emulation wizard and simulate settings according to Quick Installation Guide
Anonymous
  • Posted on Aug 31, 2009
SOURCE: dlink dap 1522
I think I was having a similar problem with my DAP-1522 ... FW Version 1.10 being used as an access point. I recently discovered that I was not able to connect to the configuration pages using a web browser by typing in it's IP address (192.168.0.50). When I originally set this up device up on my network, it worked just fine, but at some point in time, it stopped working. My solution to this problem was to set the switch on the back of the 1522 from Auto to AP, then re-boot the DAP-1522 by removing power, waiting 10 seconds, then plugging power back in. Once the AP re-booted, I was then able to access the configuration login page by typing 192.168.0.50 into my browser. My DAP-1522 access point is connected via port 1 to my D-link router, a DGL-4100, via a DGS-2208, 8 port gigabit switch. Hope this helps!
Anonymous
  • 12 Answers
  • Posted on Jul 10, 2010
SOURCE: cant konfigure router, when i type 192.168.0.50 or
Reset using the button on the back the do an ipconfig - so if you ip is 192.168.1.1 try that to get in to the router
Unable save setting dap-1360 (this feature has been disabled on this emulator)
This is the manual for this wireless access point from dlink.
http://www.dlink.com.br/sites/default/files/product_download/DAP-1360_A1_Manual_v1.00.pdf
The error message should not mention emulators, return it to where you bought it, as it sounds as if the firmware version is not correct.
Why i can not go to sit for configure DAP-1360
Go to this link http://support.dlink.com/ProductInfo.aspx?m=DAP-1360 and download the user manual for your DAP-1360. Configure it in the WISP mode following the manuals instructions.
Dap 1360
1- first distance between Dap-1360 from the router wifi Nilox should be max the signal length around 50 meter,
2- try to update the Dap-1360 software from the internet then test the network cable again and the electric cable..
hope it help ...
JE NE PEUX PAS INSTALER DAP 1360
Access D-Link's support-site: ftp://ftp2.dlink.com/PRODUCTS/DAP-1360/
Choose 'REV. A' or 'REV. B' or 'REV.C'.
Download the instructions for your router.
How to configure Dlink DAP-1360 wireless N Range
Is this the router that is currently connected to your network, and also the router that is providing you with internet right now? what would you like to setup?
After configuring dlink-1360, it says unidentified network and no internet access. what can i do to solve this problem
Power-off your DSL/Cable modem, and then turn it on.
Power-off your router, and then turn it back on.
You should now have an Internet connection.
7helpful
Cant konfigure router, when i type 192.168.0.50 or
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
