SOURCE: Konica Minolta Bizhub c203 printer
where do u scan e mail or folder? if e mail your smtp server ip may have been deleted/changed if folder the path may have changed/deleted or password changed on the server/desktop
SOURCE: How do you remove the drum unit on a bizhub C203
Just follow the procedure when you open the front cover. The Drum and Developer units are one unit. Press down to release the unlock lever of the image unit to be replaced. Then pull out the image/developer unit Black. Upper units are toner cart.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: The print margins on my Konica Minolta Bizhub c203...
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
SOURCE: how do i replace the
it is behind the right door but i doesnt need to be replaced you need a pico fuse about
$2 and it can be reset. if yoiu need more help in this and where the fuse is just ask
