Was dropped in water and put in rice, everything looks normal and there's no visible damage to the phone, but it's stuck on the lock screen. I cannot do anything I have tried taking out the battery and everything
SOURCE: HTC P3400i LCD Problem
Find a user manual incl. network settings here:
http://www.chinamanuals.com
SOURCE: it gets stuck on the windows mobile screen
You have to execute a "hard reset". The exact method depends on the exact type of HTC phone you have. You should Google for "HTC Touch <your exact phone type> hard reset" and follow those instructions.
Looking at the picture you have a HTC Touch P3450, in which case you can instructions at: http://blog.ryjones.org/2008/01/14/htc-touch-hard-reset/
Make sure you follow the instructions properly. When it still doesn't boot up, you can always perform a firmware upgrade/reset, that's almost guaranteed to work, but is complicated and might break your warranty (depending on wether you bought the device yourself or got it as part of a package deal from your provider).
SOURCE: my htc surround (windows 7
PLease do a hard reset on the phone and here is how you do it
1. Turn the phone off. If it's frozen or unresponsive, pull then replace the battery.
2. Press and hold the Volume Up and Volume Down buttons and power the phone back on.
3. Continue to hold Volume Up and Volume Down until a factory reset screen appears.
SOURCE: hello my htc hd2 for
Use your puk code to unlock HTC HD2 screen password. Type character or number until your phone request PUK code. Then type your puk code you can ask puk code from your network provider. This method should unlock htc password and reset it.
the screen has been damaged by the wateryou will have to get it fixedit wont work itself
Please note that all data will be deleted from the HTC Inspire 4G as a result of this procedure. This process may or may not delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
First, try this:
If that doesn't work, or if your phone is frozen:
All data including third-party applications will be deleted from the HTC Inspire 4G. Once the wipe is complete, the phone will reboot to its factory fresh state.
