Hello
Vertical IC inside your Sony TV has damaged [shorted]. Four blinks of standby light denotes it. The number of blinks of standbylight in Sony denotes some fault, and can be determine according the the continueous blinks. In your case, the standby light will blink four times, then stop for a while and will continue to blink four times and so on. Vertical output IC should be replaced with same type and number. If you are aware in electronics and have tools, you yourself can do the work.
If you wants anymore assistance, feel free to get me by Fixya.
Thanks for using Fixya.
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
no not at all , may be lot or h.o. transitror ar circuit dry solder, if any problem led red indicator blinks continuesly.. please chek all h.o section...and smps...
channel search
It wont turn on.only red LAD light bliking
