Have a Zanussi Frost Free fridge freezer. Ice forming in freezer and when i open the door of the freezer water comes out the bottom so its freezing and defrosting inside the freezer at all times. The drawers become stuck with ice and i have to pic and scrape it off frequently Help !!!!!
Hi, You will find that your problem relates to the defrost heater in the freezer. You will need to take the drawers out and remove the back panel to access the evaporator. There is a foil heater that lays underneath the evaporator and it will need to be changed. Along with the klixon that controls it. This will ensure that both parts are good. Your problem will then be fixed no more water!
Good luck................
Water builds up in the frezzer part (TOP) Last tim etech used a small wire but can't find hole to try and un plug.
Hello Yellow, thank you for your post!
I understand that your Frigidaire freezer is dripping water out of the corner of the door. It is possible that with your power going out the heat may have caused the gasket to warp. Do you see any frost build-up? The water that is dripping could be coming from condensation within the freezer. I would recommend checking the gasket to see if it is allowing warm air to enter the freezer.
I recommend that you visually inspect the door gasket for defects such as gaps or tears. You can also use a dollar bill to test the door gasket. Place a dollar bill in between the door and the body of the freezer. If the dollar bill pulls out with no to little resistance, you may need to replace the door gasket. A faulty door gasket can allow warm air to enter the compartment and cause frost to condensation or a leak. I hope this information is helpful. -Matt
water leaking inside frig from ceiling and had at one time thin sheets of ice under veg. drawer and sald drawer, I no longer have the ice problem just the water leaking from ceiling in frig. Please help!
i have several whirlpool fridges that have water dripping from freezer to fridge
