Jamo SUB 250 Subwoofer Logo
A
Anonymous Posted on Oct 08, 2012
How to install my jamo sub 210 subwoofer - Jamo SUB 250 Subwoofer
5 Related Answers
Anonymous
  • 238 Answers
  • Posted on Jan 12, 2008
SOURCE: Jamo 250
hi, there must be this LINE IN socket (ur so called Hole), then on the onkyo, there must be this sub-line out socket, plug one end of the RC socket to the sub out of onkyo , and other to the line in of the sub, its all to do wirth its appropriate inputs and outputs,let me know
Anonymous
  • 56 Answers
  • Posted on Mar 18, 2008
SOURCE: I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel sound from just one speaker. Simply hook up both the left and the right channels to the special terminals on the speaker. Hook up one channel only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
Anonymous
  • 19 Answers
  • Posted on Apr 03, 2009
SOURCE: sound faliure
If the subwoofer has its own power cord seperate from the rest of the audio system, the internal amplifier could be fried or u have a loose connection inside the box
Marek Podmaka
  • 127 Answers
  • Posted on Mar 03, 2010
SOURCE: my jamo sub 200 & pioneer vsx517 receiver is not working properly
What do you mean that it sometimes doesn't work? It doesn't power on automatically?
Check settings of your receiver - if it has subwoofer output enables and if low frequencies from all channels are directed also to the SUB. By default only the LFE channel (.1) of 5.1 signal input is fed to the subwoofer. So Sub will work in this case only when you listen to 5.1 signal (DVD movie for example), but for radio or stereo music, only front speakers are used. By configuring this bass redirect, you can use subwoofer for all signal types.
Marek Podmaka
  • 127 Answers
SOURCE: I have bought JAMO sub 250 subwoofer and Pioneer
You don't need such cable, although you can use it if you have one. If receiver has only mono SUB output (as majority of receivers have), you just connect it to the Left socket on the Sub and it will work.
Using the Y cable would probably cause that you will fed the same signal to both left and right sockets, but half the intensity (you would divide the output from receiver by 2). So in the end the Sub would receive exactly the same signal as when using normal straight cable.
Hi My problem is that my Jamo 200 sub sounds very
Is everything hooked up correctly sounds off I know also could be your amp is going on you cold be a multitude of problems or one of the simple ones i stated
I have a jamo 200 sub and jamo s602 speaker how do i wire so i can listen to music from my ipad to the speakers
the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
I want jamo sub 1810 circut diagram
Check out this link:
http://2getdtv.com/directv/stereo_receiver_codes.html?phpMyAdmin=ed9585cdc5a4551847999cb4dbcce76a
1helpful
I was given a Jamo sub 1810, but have no instruction manual. I'm trying to hook up to my Pioneer HTP-2500 home theater system. What would be the correct way? Also if you could help me with the setup,...
Find it here...
http://www.jamo.com/na-en/support/owners-manuals/
http://www.jamo.com/images/download/779.aspx
The Jamo is self-amplified and accepts Line Level input ONLY.
The HTP-2500 receiver drives a subwoofer directly with SPEAKER LEVEL output only and does not have a volume-controlled output for driving externally-amplified devices.
6helpful
Cant connect jamo sub 250 to marantz SR4001... how do i do it? any suggestions?
Use the PRE-OUT SW (subwoofer) output and connect it to the left RCA socket of your subwoofer.
Sound faliure
2answers
Dual Voice-Coil
Jamo 250
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
