To set the time it says to
1) pull the crown out to position c
2) turn crown to set hour and minutes
3) push in crown to position a (all the way in) to set
After performing these steps, the main hour, minutes, and seconds hands do not move at all. The little bottom watch works, so I don't think it's a problem with the batterys/
Here is how to set the Invicta 6106 Invicta 6107 and other similar models with the ISASWISS 8173 movement with the following functions:
TIME - DATE - DAY - ALARM - GMT - POWER RESERVE
DO THINGS IN THIS ORDER AND YOU WILL FIND IT TO BE VERY EASY! After you understand how to set ALL the functions you can skip steps later to set individual functions but for now just do it exactly step by step:
1. Unscrew the center crown (if it is a screw down crown) and pull it all the way out (this is position 2) and turn it until you see the DAY sub-dial at the 6:00 position set to the day BEFORE today. There is no QUICK SET for the day on this movement so you must just keep turning the crown and hour hand past 12 midnight and watch the day pointer until it gets to the day you want - the day BEFORE today.
2. Now set the time to 6:00 (am or pm doesn't matter at this point). This is very important because you do not want the time to be between 9:00pm and 12:00pm when you set the date later on - we are using 6:00 just to be safe.
3. Push the crown all the way in - you don't have to screw it down.
4. Now pull out the crown very gently to the 1st position - just one "click" out. Now turn the crown AWAY from you to set the date to the date BEFORE today - this appears in the small window at the 4:00 position.
5. Now pull the crown all the way out again to position 2 and turn it away from you until it goes past 12 midnight and TODAY's DAY AND DATE are showing and then adjust the hour and minute hands to the current time - be sure to set the hour to AM or PM and push the crown all the way in. If you wish to set the seconds exactly - with the crown pushed in watch until the small seconds hand in the sub-dial at 2:00 is exactly at 60 and then pull the crown out to Position 2. Set the time ahead a minute or so and push the crown in when the actual time is the time you have set - you can set it to atomic clock time on the internet or by another watch that sets itself to atomic time.
6. Now the DAY, DATE and TIME are set to current. Now when the hour hand passes 12 at midnight tonight the DAY and DATE will advance correctly.
YOU CAN STOP HERE IF YOU WISH - but you can continue on to set the ALARM and the GMT indicators as follows:
7. To set the GMT hand (the one with the red-bordered pointer) the crown is pushed all the way in and screwed down. Now simply hold the bottom pusher in for a few seconds until you hear a beep - now you can start pushing it and watch the GMT hand moving - one push at a time for small adjustment or hold it down to make it move faster. When you stop pushing it another beep indicates that it is OUT of the setting mode - so if you want to adjust it again just hold it in until short beep and start pushing the lower pusher same as above.
Understanding GMT (or second time zone): Note that the GMT hand time is indicated on the 24 hour dial (think in military time where 3:00AM is 0300 and 3:00PM is 1500) using the very small numbers around the very outside of the dial. When the local time is 3:00PM if GMT is adjusted for the SAME TIME ZONE as you are in now the GMT HAND will be pointing at the small "15" which is between the 7:00 and 8:00 hour markers. If the local time is 3:00AM and the GMT is adjusted for the SAME TIME ZONE as you are in now the GMT HAND will be pointing at the small "3" between the 1:00 and 2:00 hour markers. So lets say you are in Pacific Time Zone and it is now 3:00pm local time and showing on the minute and hour hands - and for example you want the GMT hand to show Eastern (New York) time which is 6:00pm (in military time that is 1800 indicated by the very small 18 which aligns with 9:00) - hold in the bottom pusher until you hear a beep - now start pushing it in short increments or hold it down to move it faster until it points to small 18 (large 9). Now the GMT will indicate the hour in the EASTERN time zone while the main hour hand indicates your local time.
7. To set the ALARM - unscrew the crown and pull it to Position 1. Turn it TOWARDS you (if you turn it way from you will set the date which you don't want to do) and you will see the hand with the white pointer and the word "Alarm" in tiny writing on it move clockwise. Set the ALARM to the time you want. Push in the crown and screw it down.
8. To activate the ALARM push the TOP PUSHER once - the small hand in the POWER RESERVE sub-dial will move slightly and then it will move again (give it a second or so) and you will hear a BEEP - now the alarm is activated and the small hand points to the "ON" label. When the alarm sounds if you wish to stop it push the top pusher. But it will stop on its own and then repeat a few minutes later - you can just leave it alone if you wish. Note that the Alarm will turn OFF after sounding - so if you want to wake up for work on time tomorrow be sure the ALARM indicator is pointing to "ON".
9. To deactivate the ALARM when the small hand is pointing towards the "ON" label simply push the top pusher again and and the small hand will move clockwise down to the "OFF" label.
10. POWER RESERVE sub-dial. To align the Power Reserve sub-dial hand (after battery change) pull the crown out to Position 1 and push the top pusher until the hand points to 0%. Push the crown back in and screw it down.
11. Reserve Indicator - the instructions for this movement states that holding down the top pusher for 3 seconds will move the POWER RESERVE hand to the power reserve scale - but this is confusing because the hand never actually stays on the power reserve scale - it will only stay on "ON" or on "OFF".
However - I believe that this is the way it works. When you push the top pusher with the small hand in the "OFF" position it will momentarily move to the power reserve scale and stop for a second before it moves again to "ON" - I believe that this reading indicates the POWER RESERVE just before it moves again to the "ON" position..
Normal screwed down. First pull out position. Second pull out position.
Setting the Time: Pull out the crown to position 3. Rotate the crown to set the exact time. Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not. If the date changed, then you will need to advance at least 2 hours before moving on to set the date. If you do not need to change the date, return the crown to position 1.
Setting the Date: DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am Pull crown to position 2. Rotate the crown clockwise to set to the correct date. Return the crown to position 1.
Setting the Alarm [12 hour] Pull the crown to position 2. Rotate the crown anti clockwise to move the alarm hand to the desired time. Return the crown to position 1. To activate the alarm, press the 8 o'clock button. You will hear 2 beeps. To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep. NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life] The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown You can specify a countdown of between 1 and 10 minutes. Press the 4 o'clock button to enter setting mode. You will hear 1 beep. Press the 4 o'clock button to move the central timing hand successively to the desired countdown time. Wait 3 seconds for the watch to automatically exit the setting mode. You can change the duration of the countdown [except in the last minute] at any time. e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown: Press the 2 o'clock button to start the countdown. You will hear 2 beeps. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing. When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone: There are 2 beeps every minute. in the last minute: 50 seconds=1 beep. 40 seconds=1 beep. 30 seconds=2 beeps. 20 seconds=2 beeps. 10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer: After countdown has finished the timer starts automatically. The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96. Press the 4 o'clock button to see the timer seconds [display lasts up to a minute]. Press the 4 o'clock button to see the timer hours. The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer: Press the 2 o'clock button to stop the timer. You will hear 1 beep. Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer: Countdown reset: Press the 2 o'clock button to stop the countdown. You will hear 1 beep. Press the 4 o'clock button to reset.
Setting the Timer: Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes. Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial. Press the 4 o'clock button to reset.
Resetting the Hands: If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation. To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second. Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12]. Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60. To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position. Return the crown to position 1.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Thank you for contacting FixYa.
Multifunction watch:Pull the crown out to position No. 3, turn clockwise to go to hour and minutes hands; the small dial showing days of the week will move, and the 24-hour dial will also move correspondingly.To set the date, pull the crown out to position No. 2 and turn clockwise until you have set the desired date; push the crown back to position No. 1.
Unscrew the crown (the main knob on the center right side of the watch casing), wait until the second hand is at the 12 o'clock position, and pull the crown knob up so that it clicks once.
Press the button below the crown knob repeatedly until the hands of the alarm dial point to the time within the next 12 hours that you want the alarm to ring. Pressing the button once will move the alarm one minute forward. Pressing and holding the button will move the alarm forward quickly.
Pull the crown knob one click further out and turn to adjust the main hands to the correct time, to take into account the time you took to set the alarm.
Push the crown knob two clicks back into its normal position, and screw it into place until it locks.
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note: The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10 BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
I did find two authorized dealers: www.kenmarwatches.com www.princetownwatches.com Contact both and request users manual fur your specific model. They must be able to help.
This is the movement used in the following Seiko watches.. SNAC74 SNAC75 SNA548 SNA694 SNAC40 SNAC41 SNAC42 SNA749 SNAC03 SNA411 SNA414 SNA765 SNAA03 SNAA05 SNAA01 SNAA02 SNAA61 SNAB61 SNAB62 SNAB64 SNAB65 SNAC25 SNAC29 SNAC35 SNAC36 SNAA61 SNAC38 SNA283 SNA695 SNAA30
HOW TO SET ALARM TIME 1. Pull the crown out to the second click position. 2. Press button “B” to set the alarm hour and minute hands to current time. 3. Push the crown back to normal position. 4. Pull the crown to the first click position. 5. Press button “B” to set the alarm hour and minute hands to desired alarm time. 6. Push the crown back to normal position.
Note: Alarm setting on a 12-hour basis only. Alarm will ring at the designated time for 20 seconds; one time alarm only. The alarm needs to be reset in order to re-engage the alarm function.
HOW TO USE CHRONOGRAPH 1. Set crown at normal position. 2. Press button “A” to Start/Stop/Restart. 3. Press button “B” to Split/Split release/Reset.
HOW TO USE ALARM DIAL AS DUAL TIME DISPLAY 1. Pull the crown out to the second click position. 2. Pres the button “B” to set the hour and minute hands to time of a different time zone. 3. Push the crown back to normal position.
