LD 035
SOURCE: Lanier LD 024c
You need to check the DNS server. Press user tools, system settings, interface settings. This screen will display IP address settings. There is a DNS selection. Put the Ip address for the DNS in there. (obtain by, Windows desktop screen, Start, run, type cmd in the input box, enter, at the prompt, type ipconfig /all. it will bring up your settings. write down the DNS setting.)
Now, your SMTP server setting can be obtained by going into your Email account settings. There will be a spot for servers. If you are using Microsoft exchange server, you can use the server name or its IP address. Otherwise, it will be your ISP email server setting. You can just call your ISP and get the outgoing server name. Once obtained, go into user tools. system settings, file transfer and plug in into the SMTP option. I think if I'm not mistaken, there is a connection test there as well. (The 024 might be too old to have that) That should do it. You may need to enter in a email name and password for athentication.
If you have any problems, you can call the Lanier help desk too. 800-424-1573
SOURCE: lanier LD 325 Printing labels
4 x 6 might be too short for that copier to run on. The bypass tray might take it if you load it so that the 6" side is the longest end that the copier is feeding throught the machine.
If you have it interfaced as a printer, goto avery.com and download their label making software and find the template that matches your label stock. The software works with Microsoft Office files as well.
SOURCE: sc 544 lanier ld 122
CALL FOR SERVICE YOU WILL NEED NEW THERMISTORS NEW THERMOSTATS AND MOST LIKELY HOT ROLLER,CLEANING ROLLER AND HR BEARINGS COST OF TIME AND PARTS WILL BE 400 TO 500
