I lost the remote and the manual power button don`t work, so i was wondering is there another way to turn on the tv?
Download your instr. manual from www.fitness.manualsonline.com or
www. retrevo.com
God bless you
SOURCE: REMOTE DONT WORK WITH MY TV
hi go here for the complete usermanual, and try thid following.
If none of the codes listed under
“Device Codes”on the back of this
guide match your device, you can
search for a set of commands that will
work. Your remote will sample all the
codes in its system for that device
mode to find one that will allow you to
control your device.
1. Press and hold a device mode
key (AUDIO, DVD/VCR, or TV) for
at least six seconds. The LED for
each device key lights up, then
the key for the device you
selected remains on.
2. Press a function key (such as
Power or Mute). The following
function keys are valid for
Searching (Power is
recommended):
• Power
• Mute
• Play
• CH +
• Stop
The device key’s LED blinks
three times, then turns off.
3. Press !. The remote will send
the IR command for the function
you pressed in Step 2.
4. If the device performed the
function you pressed, press OK.
The remote will now control the
device you selected in Step 1.
If the device did not perform the
function you pressed, repeat step
3. Press " to retry the previous code
I hope this helps
Please rate accordingly
Thank You
sserpentio
SOURCE: remote dont work with my tv
Searching (Power is
recommended):
• Power
• Mute
• Play
• CH +
• Stop
I hope this helps
Thank You
sserpentio
SOURCE: Tried everything, but can't find the right code to work.
While this isn't really a solution, I have the manual and it doesn't list an Emerson DVD/VCR (EWD2204) that I have. I can't get it to work with my VCR. I bought the RCE Universal remote (RCU703SP) at Lowes (in 2008). I can't help but notice that the date on the package is "2004 Thompson, Inc." I know that the DVD/VCR is newer than that. Perhaps this remote is a bit old (explains why it was cheap?) Anyway I did find a site that you can get the codes like in the instructions: http://remotefinder.rca.com/default.aspx?site=rca so hope this helps.
SOURCE: I lost my remote control TV. DIGISTAR a universal
Go buy a Logitech Harmony remote from Future Shop or Best Buy 300 ($50), it works.
