Need help with this ASAP as I don't want too loose the photos I have on the phone.
You need to hard reset the device in order for the force close errors to stop. As long as you have an sdcard your photos should be backed up.
To Hard Reset follow these directions
http://www.androidpit.com/en/android/forum/thread/429809/Samsung-Galaxy-2-Performing-a-hard-reset
SOURCE: My motorola flipout phone. Upon opening, the phone
Goto
Settings > applications > Manage Applications > Home > Clear
Data.
If this does not help , then Perhaps you have too many background apps open thats making
it crash?
I would suggest going to the market place and finding
"TasKiller" it eliminates any and all apps that may be taking up memory
from working in the background. It comes with a widget you can add to
the homescreen for one touch elimination. after it clears everything
your screen will be black and then might go to call log screen. Just hit
the home button and everything will run like normal but it will be much
lighter on the memory.
SOURCE: i need to hard reset my sony ericsson e15i it shows force close
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
