Picture is kinda snowy scrabled with lines going through the middle
SOURCE: i have a lg lcd
That is caused by a failure of the t-con board - the board that actually commands the screen, connected to it directly by 2 wide ribbon connectors. You must replace it, a new one will cost you less than $90.
SOURCE: LG 50 PX1D PROBLEM. Screen is snowy, with a kind
This could be internal power supply noise. If you are experienced atTV service you can use a scope and go through all the power supplydistributions to see if any of them are noisy.
Another cause could be a defect somewhere along the digital signalpath. There could be some system clocking errors, or some noise generation taking place.I recommend have it checked by a Service Technician for faulty parts.
SOURCE: I have an LG RM-26LZ30
This kind of symptoms indicated of faulty T-con board. This board is responsible for processing the video from the mainboard and will feed to the LCD panel. Replaced this board and it will back to normal operation again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
