SOURCE: ricoh 1045 error code sc 672, 961
Controller to operation panel comucation error at start up.Check the controller stall,controller board installed correctly operation panel connectors.Enter im the service menu ,press the SP mode,open the front door,turn off the copier,unplugged the machine.Wait 10 seconds,plugged on the machine,close the front door,turn ON the copier and make a copy.
SOURCE: ricoh 1045 showing code SC545. First was SC 546
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
SOURCE: Sir my Ricoh 1045 machine have SC 326 problem,
sc326 is a laser synchronization error. The problem is usually caused by the laser sync detection board or the LD unit.
