SOURCE: find board for maax bubble-tub
You will probably have to go to the manufacture website to find a dealer in your area that you can purchase one from. Also, you can check online as well for specific parts for your tub. If often just google the brand and model number and start clicking on links to find what I want or need. Good luck to you!
SOURCE: E06 on newly installed maax calla
E06 is the water sensor, The tub will not operater if there is not enough water in it. If the water level is not the problem, it is most likely a bad water level sensor.
SOURCE: Maax bathtub Palace model Error code C01 jets don't turn on.
first of all check the circuit breakers to be sure one or both aren't kicked. be sure to turn the breaker all the way off and then fully on as a tripped breaker is in a halfway off position. if that doesnt fix your problem remove the access panel to the mechanical space in your tub. there are generally one or two reset buttons in there which can also kick off and need to be reset.
SOURCE: my bathtub jacuzzi wont work. I reset the circuit
make sure you have power to outlet that motor is plugged into,if so try pushing jet button in tub about ten times in a row quickly then on tenth push use as much force as possible and hold.if this does not work,air hose from back of button to pump motor may be disconnected.
SOURCE: Hello, I don't have a problem,
your friend is correct. Actually the oils will not hurt the system either but not sure about Oatmeal in the tub. As long as the jets were not turned on with the Oatmeal thingy going you would be just fine.
