Sony PlayStation 2 (PS2) Console Logo
Posted on Oct 07, 2012
Ps2 Disc won't respond to a Ps3 when inserted.
I got my ps3 2 years ago and i installed a Add-On Called Ps2 System Data. When i put my Ps2 Disc into the Ps3 it doesn't Read it. Nothing shows up.
Shafique
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Oct 30, 2012
Shafique
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
311
Points
17
Only the first version of the PS3 had PS2 backwards compatibility, They did make a special edition Metal Gear Solid version with it included but other than that no other PS3 will play PS2 discs... No matter what Add-On you install.
5 Related Answers
GTA4guy
  • Posted on May 01, 2008
SOURCE: won't play PS3 games
I have a 60GB unit and it wont read any BD discs or games. I left my system on for about 1/2 hour and then it started to read the games. Ive done this twice now and it seems to work.
bosh04
eric Korey
  • 3 Answers
  • Posted on Jun 14, 2008
SOURCE: PS2 not responding to commands from remote or controller
Try blowing into the controllers plug and then blow into the slot in the ps2
Anonymous
  • 80 Answers
  • Posted on Jun 21, 2009
SOURCE: my ps2 screen says 'insert a playstation or a ps2 format disc
The problem is that this code is generic and not real specific. It used to happen to me all the time. It could mean that the disc is dirty or scratched, the lens needs cleaning or it could mean that your PS2 is being stupid not wanting to read the disc. If the disc is dirty just take some eye glass cleaner and wipe from the center to the outer edge of the disc. If it is scratched, you can take it in to be resurfaced. This usually cost about five dollars. A lens cleaner is about the same depending on where you go. You may want to invest in a can of air duster. Somtimes the dust inside it makes it go haywire.
Anonymous
  • 81 Answers
  • Posted on Aug 04, 2009
SOURCE: 40gb ps3 wont read any disc
hi, your ps3's drive laser head is faulty making it unable to read any discs, you need to get this repalced, if under warrenty it will be free.
Anonymous
  • 187 Answers
  • Posted on Sep 22, 2011
SOURCE: ps3 won't read game discs
hey there boppa252001
OK so you have the DISK READ ERROR
Not to worry this can be fixed, I will give you 2 options below for the best possible fixes.
Option 1 SONY
Call Sony they can have this fixed within 4-6 weeks for a cost of $150 but it is free if your still in warranty (12 months)
Option 2 YOU
You can repair this problem quite easily with the help of a great ps3 repair guide that many use to fix there PS3 problems themselves within hours rather than weeks.
You will soon be back up and running using any of the above options
Peter
Pes 2013 for play station 2 won,t start
The game is for the PS3, not the PS2, which means it won't play on an older system.
1helpful
3answers
Playstation 3 hard disk files corrupted???
hey ash,
ps3 Hard drive needs to be manually reformatted and checked for bad sectors.
as what youve said, you already formatted it and yet it still says there is a corrupt system file.
when i say "manually formatted" you have to clearly take the hard drive out and format it using another pc or ps3.
tip
Check Your Playstation 3 Error Code
<span style="font-weight: bold;">Error Code - Meaning/Suggestion/Possible Fix:<br /><br /><span>0710102 - DNS Error: No DNS server available.</span><br /><br />80010001 - Major Error, Game ability stopped.<br /><br /><span>80010006 - An error occurred during the start operation. - Corrupted folding install.</span><br /><br />80010007 - An error occurred during the start operation. - During the (internal) hard drive disk swap tests. suggests a failure with the hard drive.<br /><br /><span>80010017 - Can't start Blu-ray Game</span><br /><br />8001050B - Will not play demo game from the hard drive. When a Blu-ray disc is inserted. - Cause unknown".<br /><span><br />8001050D - An error occurred during the start operation; PS3 game swapped using the eject function and then play pressed quickly. - Insert PS3 game again.<br /></span><br />80010510 - Will not play games installed on the hard drive. - Cause unknown.<br /><br /><span>80010516 - An error occurred during the start operation: PS1 game swapped using the eject function and then play pressed quickly. - Insert PS1 game again.</span><br /><br />80028EA5 - Unknown. User cannot connect to Playstation Network ("PSN"). Contact Sony for resolution.<br /><br /><span>80028EA6 - Connection Error: Turn off PS3, unplug router and modem. Turn on modem and allow it completely boot-up and synchronize. After the modem shows that it is "online", then plug in the router and allow it to completely boot. Lastly, plug-in and turn on the PS3.</span><br /><br />80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automatic.<br /><br /><span>80028F17- PS2 Disc Boot Error. An error occurred during the start operation: PS2 game swapped using the eject function and then play pressed quickly. - Insert PS2 game again.</span><br /><br />80028F18 - PS2 Disc Error. Unsupported disc: eg. Utility discs, BB discs, IQ Remix game etc.<br /><br /><span>80028F19 - PS2 Disc Error. Fsck: the internal PS2 disk was corrupted. You may be able to use the HDD utility disc to fix it (use with caution), otherwise, contact Sony.</span><br /><br />80028F1A - PS2 Disc Error. invalbnnetcfg: network config error.<br /><br /><span>80029023 - Exchanging Key Information: exchange has timed out.</span><br /><br />80029024 - Cannot obtain an IP address. DHCP failure. Check network connection, modem and/or router.<br /><br /><span>80029301 - An error occurred during the delete operation: attempting to delete PS2 data from virtual memory card.</span><br /><br />80029513 - Copyright Violation when attempting to install game.<br /><span><br />80029516 - Sign in to PLAYSTATION-Network: needed for some games or PS3 processes. Sign-in is required for current operation/request.</span><br /><br />80029564 - Downloaded game will not install: Cause unknown.<br /><span><br />80029945 - Can't playback burned BDr movie: Error in picture.</span><br /><br />80029946 - Attempting to play burned Dual layer NTSC disc on a PAL PS3. The workaround is to transfer files to the PS3 via TVersity.<br /><br /><span>80029C68 - Corrupt data. Usually on an external device.</span><br /><br />8002A10D - Unable to Add friend in XMB. (Normally because you have reached the limit of (100 friends)<br /><br /><span>8002A4A6 - Cannot load game to play online.</span><br /><br />8002A515 - Error Signing in.<br /><span><br />8002A548 - Unable to remain logged in. Either due to game or server.</span><br /><br />8002A705 - Unable to connect to server/host. If you are using a router, check port/DMZ configuration.<br /><span><br />8002A71A - Possible NAT Error. Can log into Game Server but can't join game and can't host game. Turn off the PS3 and wait for 5 minutes.</span><br /><br />8002B241 - DVI has no audio.<br /><span><br />8002F994 - Too many people currently downloading the update. Server(s) at capacity. Wait and retry</span>.<br /><br />8002F997 - Trying to Update the XMB Firmware: Copying to a file and installing from a USB drive failed.<br /><span><br />8003041F - An error occurred during the copy operation. (Using media server)</span><br /><br />8003051E - Game will not Save.<br /><span><br />80030920 - An error occurred during the copy operation. The file may be corrupt or there isn't enough memory. Try copying data from original source.</span><br /><br />80031150 - System Settings Fail to Save. Possible Blue Screen Setting information is corrupted.<br /><br /><span>80031601 - Error Creating Account.</span><br /><br />8013013D - A connection error has occurred: Causes may include the actual SSID of the wireless access point/router or signal strength. If the connection drops, try enabling DMZ functionality on your router (if supported) for your PS3. Otherwise check WPA key. The PS3 wireless interface [currently] does not support WPA2 - only WPA, WEP or none.<br /><span><br />8013013E - WEP Key error: Change WEP key to *only* numbers and try again, or switch to WPA.</span><br /><br />80130203 - PS3 connects to the internet (you can go a website via the PS3's browser), but cannot connect to the Playstation-Network. Typically this means that the required ports are not open/accessible. Check your router's configuration.<br /><br /><span>8013030 - System Error: Due to failed update download.</span><br /><br />8013030F - Access Point was not detected. Check your router's configuration and make sure that SSID broadcast is enabled.<br /><span><br />80410418 - DNS Error.</span><br /><br />80410A0B - Internal error: "Hardware Fault". Send unit back to be replaced/fixed.<br /><span><br />80710016 - The Playstation Network is down.</span><br /><br />80710092 - "An error has occurred. you've been signed out from the Playstation-Network". Connection dropped? If your PS3 is wireless (least preferred), the association between the PS3 and the access point may have been dropped. You may need to "reboot" your PS3 if your PS3 and router are unable to establish an association.<br /><br /><span>80710101 - Connection error.</span><br /><br />80710102 - IP Address conflict. PS3 cannot connect to your router with it's current IP Address information. Try rebooting your router and PS3. Occurs when two devices on your network have the *same* IP Address.<br /><br /><span>807101FF - An error occurred during communication with the server. This is a DNS error. It occurs when your PS3 tries to perform a DNS lookup to connect to the server.</span><br /><br />8071053D - Hard boot the PS3. Turn off the PS3 via your controller (this is stand-by mode), Turn off the PS3 switch on the back of the PS3 and remove the power cord. Next, turn-off/unplug your modem (and router if applicable) for about 5 minutes. Then turn on the modem and wait for it go "online". If you have a router, turn it on and wait for it go "online". Then turn your PS3 back on and make a new network connection.<br /><br /><span>80710541 - The connection to the server timed out. This is usually due to: high traffic (between you and the server), high traffic at the server [itself] or you have a "poor path" to the server. Depending on result: Press the 'X' button to repair and restore default.</span><br /><br />80710723 - Possible Port Error: Try opening ports. Configure your router to pass the following ports to your PS3:<br />TCP ports: 80, 443, 5223<br />UDP ports: 3478, 3479, 3658<br />Another option is (if your router supports DMZ functionality) to configure your router's DMZ functionality to pass traffic to your PS3.<br /><br /><span>80710A06 - An error occurred during the install operation. Error when downloading game from the Playstation-Network. An error occurred.</span><br /><br />80710B23 - Playstation-Network is down or Playstation-Network is too busy to respond.<br /><span><br />80710D23 - Turn the PS3 off for a bit. For 30 minutes give or take. Make sure that you either unplug or actually turn off the switch (located on the back of the PS3). "Stand-by" mode is when you see the red LED on the front of the PS3. If you see the red LED on the front of the PS3, your PS3 is *NOT* off.</span><br /><br />81019002 - Error copying saves from location "A" to location "B" not open to connect to store but PS3 can connect to internet.</span>
tip
PlayStation 3 ERROR CODES
Complete PS3 Error Codes:<br /> <br /> <br /> 0710102 - DNS Error; No DSN server available.<br /> <br /> 8013030 - System Error due to failed update download<br /> <br /> 80010001 - Major Error , Game ability stopped<br /> <br /> 80010006 - An error occurred during the start operation (corrupted folding install)<br /> <br /> 80010007 - An error occurred during the start operation (during disc swap tests)<br /> <br /> 8001000B - it happens when trying to establish wireless connection<br /> <br /> 80010017 - Can't start BlueRay Game<br /> <br /> 8001050B - Will not play demo hard drive games, (when blue-ray disc is inserted) - cause unknown<br /> <br /> 8001050D - An error during the start operation; Ps3 game swapped using the eject function and then play pressed quickly - ps3 game inserted again<br /> <br /> 8001050F - Hardware failure. Cannot update firmware or connect to internet.<br /> <br /> 80010510 - Will not play games installed on the hard drive<br /> <br /> 80010514 - Possibly reading blu-ray disc problem<br /> <br /> 80010516 - An error occurred during the start operation; Ps1 game swapped using the eject function and then play pressed quickly - ps1 game inserted again<br /> <br /> 80023101 - Unknown<br /> <br /> 80028E07 - which pops up when i try to update to 1.93 and says that i have been disconnected from the server<br /> <br /> 80028EA5 - User cannot connect to PS3 network<br /> <br /> 80028EA6 - Connection error , Possible Proxy error power cord. Then shut off your modem/router, for about 5 minutes, then turn the modem back up first and let it sync, then turn the router back on(if using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection.<br /> <br /> 80028EA8 - Seems to mean unable to authorize isp account details<br /> <br /> 80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automatic,<br /> <br /> 80028F17 - Ps2 disc Boot Error , An error occurred during the start operation; Ps2 game swapped using the eject function and then play pressed quickly - Backup ps2 game inserted again<br /> <br /> 80028F18 - Ps2 Disc Error, unsupported disc; eg. Utility discs, BB discs, IQ Remix game etc. ode).<br /> <br /> 80028F19 - PS2 Disc Error , fsck; the internal PS2 disk got corrupted and I guess that you can use HDD utility disc to fix it<br /> <br /> 80028F1A - Ps2 Disc Error , invalbnnetcfg; network config error<br /> <br /> 80029023 - Exchanging Key Information exchange has timed out<br /> <br /> 80029024 - "The attempt to obtain an IP address has timed out".<br /> <br /> 80029301 - An error occurred during the delete operation (attempting to delete some ps2 homebrew from virtual mem card)<br /> <br /> 80029501 - connection<br /> <br /> 80029509 - When the PSN network is down for maintenance.<br /> <br /> 80029513 - This content cannot be accessed on your account (80029513)<br /> <br /> 80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3 processes - have to sign in to use them)<br /> <br /> 80029564 - Downloaded game will not install<br /> <br /> 80029751 - warhawk wont start but eveything else seems ok<br /> <br /> 80029945 - Can't playback burn BD movie<br /> <br /> 80029946 - Attempting to play burnt Dual layer NTSC disc on a PAL ps3 ( workarounds is to transfer files to ps3 via TVersity )<br /> <br /> 80029C68 - Corrupt data usually on external device<br /> <br /> 8002A10B. It shows up when I try to view my friends trophies, profile etc.<br /> <br /> 8002A10D - Unable to Add friend in XMB<br /> <br /> 8002A4A6 - Cannot load game to play online<br /> <br /> 8002A515 - Error Signing in<br /> <br /> 8002A524 - connection<br /> <br /> 8002A548 - Unable to remain logged in - either to game or server<br /> <br /> 8002A705 - Unable to connect to server/host. Check router port configuration.<br /> <br /> 8002AD23 - Unknown<br /> <br /> 8002AD3D - Cannot Log into PSN - Is the PSN down? Try manually configuring your PS3 IP info. Try disabling medai server connection in the PS3.<br /> <br /> 8002B241 - DVI has no audio.<br /> <br /> 8002B71A - Possible NAT Error , Can log onto Game Server but can't join game and can't host game<br /> <br /> 8002F994 - Too many people downloading the update (download it later on)<br /> <br /> 8002F997 - Can not update XMB firmware<br /> <br /> 80030001 - Deleting messages from inbox<br /> <br /> 8003041F - An error occurred during the copy operation (using media server)<br /> <br /> 80030517 - It seems to happen when you copy large media files.<br /> <br /> 8003051E - Game will not save<br /> <br /> 80030920 - An error occurred during the copy operation, the file may be corrupt or there isn't enough memory (Try copying data from original source)<br /> <br /> 80031150 - "Setting information is corrupted.Press the x button to repair and restore default"<br /> <br /> 80031601 - Error Creating Account<br /> <br /> 8013013D - "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the connection drops Putting the PS3 into DMZ may help - otherwise check WPA key Ps3 can't handle WPA2 only WPA or none<br /> <br /> 8013013D - connection<br /> <br /> 8013013E - WEP Key error, change WEP key to all numbers (on router homepage) and try agian, or which to WPA. - Otherwise disable security<br /> <br /> 80130203 - PS3 connects to internet but not to network - Typically means that the required ports are not open to connect to store but PS3 can connect to internet.<br /> <br /> 8013030F - Access Point not detected<br /> <br /> 8041040F - Communication with the server failed. A dsn error has occured.<br /> <br /> 80410418 - DNS Error<br /> <br /> 80410A0B - Internal PSP error, hardware fault. Send back to be replaced/fixed.<br /> <br /> 80710016 - Playstation Network is down.<br /> <br /> 80710092 - "An error has occurred. you've been signed out from the ps network" , "Media Server Error: A network error has occurred (80710092)"<br /> <br /> 80710101 - Connection error<br /> <br /> 80710102 - IP conflict , PS3 Cannot connect to the router with current IP information - Try rebooting your router<br /> <br /> 807101FF - An error occurred during communication with the server. This is a DNS error - This is a DNS error<br /> <br /> 8071053D - Hard boot the PS3, turn off the PS3 to stand-by, flip off the back switch and completely remove the power cord. Shut off your modem/router, for approx. 5 minutes, then turn the modem back up first and let it sync. Then turn the router back on (if you're using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection<br /> <br /> 80710541 - The connection to the server timed out.<br /> <br /> 80710723 - Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ<br /> <br /> 80710A06 - An error occurred during the install operation (error when downloading game from PSN - network error occured<br /> <br /> 80710B23 - PS3 Network is Down or PS3 Network is too busy to respond<br /> <br /> 80710D23 - Turn the PS3 off for approx. 30 minutes with the power toggle, not standby mode<br /> <br /> 81019002 - Error copying saves from location A to location B not open to connect to store but PS3 can connect to internet.
2helpful
Sony PS3 ERROR CODE 80710092?
here are some of the ps3 error code that might help you in the future..
80023101 - Unknown
8002AD23 - Unknown
How to change ps3 setting to play ps3 games
create a memory card then selet ps2, then insert a ps2 disc :)
2helpful
2answers
How to play ps2 game on the ps3
Playing a PS2 game on a PS3 depends on what model your PS3 is. The 40 GB does not play PS2 games, the 60 GB definatly does ,and i dont think the 80GB does
PS3 will only play PS2 games and blue ray disc
same thing happened to me two days ago, it would play everything but ps3 games. i called sony and they said it would be $150 again (in april i had a yellow light failure) so i looked online and someone suggested reformatting the harddrive and now it works fine......thank god
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
