Helicopter spins in circles when launched in the air and falls to the ground very quickly still spinning - the nose goes down first vertically. Blue charge? lights are flashing before,throughout and afterwards. Blades are going round full speed when on button is selected.Helicopter spins in circles when launched in the air and falls to the ground very quickly still spinning - the nose goes down first vertically. Blue charge? lights are flashing before,throughout and afterwards. Blades are going round full speed when on button is selected.
You can't post conmments that contain an email address.
many reasons for this, first tail rotor, then controller. but if the tail rotor in not working all it will do is spin just like the real ones I flew in the military.
Just bought the air hogs helicopter with the crane. Had the aircraft constantly spinning clockwise, no matter how much I turned the trim control counter clockwise the aircraft still rotated. I then turned the trim control in the opposite direction until I noticed the aircraft had stopped spinning, and used the rudder control to fine tune forward flight.
So, get the aircraft to hover and turn the trim button in the opposite direction until you see that the aircraft spinning slows right down. If you continue to turn the trim control in the same direction the aircraft will increase its spin, so just dial back the trim.
have you tried using the trim buttons?,after take off when its around 2ft in the air if the tail spins to the right tap the left trim button a few times and if its spinning left tap the right button a few times and this should stop it spinning it works ok on my one
i would continue to hold the trim. this happended to mine and i held the trim for a couple of seconds and it leveled out. also i have a problem, mine wont generate enough lift to take off. do you have a solution for that?
have you made sure that the helicopter is charged completely?
if so when you try to take off if it spins to the left then hit the r trim on the remote and if it spins to the right then hit the l trim on the controller.
honestly all the instructions do is tell you how to put batteries in the controller.
