I formatted it to delete songs and now I cant get it to turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button. Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode. Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear. Properly disconnect your GoGear from your computer and restart the device. Connect the GoGear to your computer via the supplied USB cord. Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on. This will begin the charging process of your GoGear. If recharging doesn't work, the battery may need to be replaced. Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on. hope this helps
Recharge your device if your GoGear dies suddenly while playing.
SOURCE: iTunes to MP3 player
your going to need a conversion program because most likely the itunes files are .acc and not.mp3 so find a nice little converter and enjoy
SOURCE: what video format does gogear vibe use?
well its kinda odd but so far the only format im having any luck with working it is .smv to covnert ur vids to .smv go here" http://www.soft29.com/freeware/smv_converter.htm " hope this helps
oh and btw im not saying there arent more formats but this is the onethat works for mi go gear vibe
SOURCE: my philips gogear vibe will not turn on. it is
when i hold down the turn on button.it would show the philips lable then just shut off. can you help me please.
SOURCE: Not able to play video in philips gogear pls suggets
Media players need the matching video format: for GoGear Vibe it is SMV.
To convert video from AVI to SigmaTel Motion Video, use the Media Converter Software from the manufacturer. For the videos you'd like to convert, be sure to update video codecs in Windows Media Player 10 or higher.
Vibe players have different display sizes, so you'll need the matching Converter for your player.
When you have the United States version SA5285/37 next site gives all support, including the Arcsoft video converter:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA5285/37&slg=en&scy=US
note
There's and update for the Arcsoft converter, for downloading directly YouTube films:
click on EXTRAS at the top right hand corner of the Arcsoft main screen.
At the pull down menu click UPDATE AND PATCHES, Arcsoft will check
and let user download and install the updated Stream Ripper feature
( streaming videos need flv video codec )
SOURCE: How do I delete songs
hi this is no problem for me to help you with.
You can delete the contents by two means:
a) Delete from your PC:
1. Connect your player to your PC. You player will load automatically just like the picture shown in step 2.
2. Select Open device to view file.
(If it cannot load automatically, you can double click "My Computer" and then double click the icon of your player.)
3. Select the files you want to delete.
HINTS: You can press and hold the Ctrl button on the keyboard to select more than one file.
4. Right click the highlighted files and select Delete.
5. Select Yes to confirm.
b) Delete directly from the player:
REMINDER: This method is only for player with OPTIONS / button only.
1. Highlight the file or folder you want to delete.
2. Press OPTIONS / button your player.
3. Select DELETE.
4. Repeat Step 1-3 when you want to delete more than one file or folder.
for more information refer to this help page by clicking here
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this solved your problem please feel free to rate the solution. thanks and have a great day.
