Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
Posted on Dec 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Flashing lights i can select a program the dishwasher starts then stops with the 40 deg and delicate light flashing
Paul Davies
Level 2:
  • Expert 157 Answers
  • Posted on Dec 31, 2008
Paul Davies
Expert
Level 2:
Answers
157
Questions
Helped
50080
Points
312
Heater needs replacing.
Samsung dishwasher heavy and delicate lights blink and cycle stops
A Samsung Dishwasher flashing the Delicate and Heavy light indicates a Heater Error has been detected by the internal electronic diagnostics. You can find more info here
https://appliancerepairinfo.com/samsung-dishwasher-delicate-and-heavy-light-flashing/
2answers
1helpful
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 • Dishwashers
FAST 40 DEGREE, DELICATE 50 DEGREES & SALT REFILL LIGHTS ARE FLASHING, WHAT DOES THIS MEAN?
40 and 50 degree lights are flashing on my free standing fdw60 hotpoint dish washer
1helpful
HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
1helpful
Hotpoint aquarius FDW60
I think you will find that the heater has packed up.same thing has happened to my 14month old machine.
Waiting for the part to arrive approx £40 looks quite straight forward if you are a bit handy with tools
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
