The backplate is a "pry open" back. so you will need something like a blade or a hard thin flat object to pry the backplate. once this is done you will have access to the battery. Please note that there is a tiny Philips screw that holds the battery plate. you will have to remove this screw and then remove the battery plate. Also, note that around the case there will be a thin rubber "o" ring. this is what makes the watch water-resistant. so pls male sure you fix it back when you reinstall the watch.
You need to remove the back of the watch to get to the battery. If the watch is a water proof watch then the back is screwed on. After removing the back take care not to damage the gasket. If you cannot remove the back of the watch then take it to a watch repairer, they can replace the battery and it won't be expensive.
Just hold the reset button until the seconds start blinking!!!!! Then to change secon press sec/strt button or to changr hour,min or date just press mode !!!!!!!!!!!!!!!!!!!!!!
You will need a very small (watch or glasses) Philips head screwdriver, and a SR626SW (or know as a 377) watch battery.
Remove screw 1 to remove the motorcycle back cover.
Remove the other 2 screws to take off the clock backing.
Remove the white plastic ring by pulling directly up.
Remove the battery.
Put the new battery in.
Press the white plastic ring back on.
Reassemble the clock backing with the two screws.
Reassemble the back of the motorcycle with screw 1.
To remove the battery from the back of an Oasis watch, you will need a small flathead screwdriver or a coin.
Locate the battery cover on the back of the watch. It is typically located at the 6 o'clock position.
Insert the screwdriver or coin into the notch on the battery cover.
Gently pry the battery cover off of the watch.
Remove the battery from the watch.
If you are replacing the battery, insert the new battery into the watch, making sure that it is oriented correctly.
Replace the battery cover by aligning it with the watch and pressing it into place.
If you are having trouble removing the battery cover or if the watch has a different type of back, you may need to refer to the manufacturer's instructions or consult a professional watch repair service. It is important to handle the watch carefully to avoid damaging it.
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
BASIC WATCH BATTERY CHANGE
Get a replacement battery for your watch. Some watches have the battery information stamped on the back plate. If yours doesn't, you'll have to wait until you've removed the old battery to see what kind of replacement watch battery you'll need.
Lay your watch face down on a non-scratching, non-skid surface. It may help to clamp the watch to the surface.
Remove the back from the watch. You might be able to pry it off with your fingernail, but you'll probably need a stiff, thin tool like a knife or screwdriver. You can also buy watch repair kits, which have the perfect tools for the job. Check the watch back for a small notch to insert your tool, but not all watches have these.
Remove the battery from the watch once the back is off. You might need to tip the watch over to let the battery fall out.
Insert the new watch battery into the proper space, first double-checking its size against the old battery to make sure it will fit. Press lightly into place.
Replace the back on your watch. Make sure you press firmly to get the back seated snugly.
If this doesnt work, then take to a local jeweler/watchmaker who is equipped with the right tools to assist you.
