Haier 42EP24S 42 in. EDTV-Ready Plasma Television Logo
Anonymous Posted on Oct 07, 2012
I have a haier p42lv6-hd that has a blue light but does not turn on.
When I turn on my t.v. it goes from red light to blue light but nothing happens , no video or audio.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 24, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
419
Points
The tv bulb is broken
2 Related Answers
Anonymous
  • Posted on Oct 17, 2010
SOURCE: haier P42LV6-T1 picture
when TV overheats white lines come across the screen
BElectric
DILLIGAF
  • 1140 Answers
  • Posted on Feb 09, 2011
SOURCE: I have a Haier Tv
There is no dedicated audio board in the TV, the audio processing is one of the functions of the main board, also known as the AV board or motherboard.
I'm not sure whether your comment means you have a cable box or a direct cable feed and this is not the most technical answer, but I see this problem regularly with cable boxes and it's rarely a fault with the TV. Often the firmware/software in the cable box "crashes" and needs to be "re-booted". This is similar to what happens with a PC from time to time which is unsurprising as, essentially, these devices are computers.
I'd like to suggest that you reset your cable box before looking for replacement parts / numbers. Some cable boxes have a reset button on the front. Others simply need to be switched off and unplugged from the electrical outlet for a couple of minutes. If you're doing this, you may as well unplug the TV as well and "re-boot" it.
If this doesn't work, you should also try restoring the factory default settings on your TV:
1. Switch the TV on
2. Press the "MENU" button on the Haier remote to open the on-screen menu
3. Use the CH+/- buttons to highlight "FUNCTION"
4. Press the VOL+ button to open the FUNCTION MENU
5. Use the CH+/- buttons to highlight "Restore Default Value"
6. Press the VOL+ button to activate the restore feature
Please note: After restoring the TV to factory defaults, you will need to complete the initial setup again the same as you did when the TV was new.
If you have done all of the above and there is still no audio from the TV speakers, then there is a fault with the TV and you should post back to discuss options for repair.
Before posting back, please also try plugging headphones into the headphone socket on the back of the TV and check whether you have audio in the headphones. The headphone socket is next to the antenna connection socket.
Hope this helps.
Regards,
BElectric
2answers
My Haier 50" tv won't start, there is power and when I turn it on, the red light changes to blue for few seconds and it goes back to red, nothing on the screen
Hello Mickey,
I am not familiar with your Haier...
If successful DO-IT-YOURSELF
fix is what you are interested in...
Get on the internet... use your model number to find
your power board..
Track the EXACT position of EVERY WIRE & SCREW...
Force NOTHING.
WEAR an anti-static wrist strap...
https://www.amazon.com/Rosewill-Anti-Static-Components-RTK-002-Yellow/dp/B004N8ZQKY/ref=sr_1_3?ie=UTF8&qid=1502716745&sr=8-3&keywords=anti+static+strap
and certainly verify your pack numbers yourself.
These assemblies are VERY SIMPLE... but take notes and photographs of your progress.
CARELESS will guarantee failure.
Shopjimmy.com ... AMAZON... and for the near future
SEARS sell power packs...
Sample part:
http://www.ebay.com/itm/HAIER-50E3500-POWER-BOARD-TV5001-ZC02-IP0F247785B-/172793395801?hash=item283b49fa59:g:hYsAAOSwcUBYNd1~
You can do this (maybe)
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
Universal remote code for haier tv
I have a haier p42lv6-t1 i lost my control and have brought a all in one control but it wont work when i programme it in can any one help please?
TV Not turning on , but blue power light is on
look in the back, see if the lamp is actually lit. If it is probably not a tv problem. If you can pull up the menu then you probably are on the wrong input. Are the fans running when you turn it on? IF fans are running might be lamp, if nothing is seen through the back.
Tv troubleshooting
I have a 61" JVC that just stoped working. I turn it on and nothing bu the blue light stays on and the red light blinks 8 times and then the blue light joins in.
My Haier pv50v6-a8 won't turn on
From your description it is not clear unit shuts off or the blue power indicator stays on?
If you have blue light stays on there is nothing wrong wtih power supply.
You need to trouble shoot either on Y-sus or Main board.
Good luck
Dals123.
Haier P42LV6-T1 picture
Red light blinking rapidly...no picture
Gentlemen, I have seen people with this problem and it requires the replacement of the light engine, search AVS Forum, for more information. Understand it is not cheap, hope you have ext warn.
Top Haier Televison & Video Experts
Paul Bade
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
