Hey all!!
i have an issue withj sanyo. it is stuck on the viseo one. i don thave the remote for it and it won' t change channels from the t.v itself. hopefully someone can help a damsel in ditress =) or i shall just have to chuck it =(
hmmm, terrible spelling, video one, the volumr works just fine games and movies are perfect it just wont move to any other channel, vid2 or channel 1-anythinghmmm, terrible spelling, video one, the volumr works just fine games and movies are perfect it just wont move to any other channel, vid2 or channel 1-anything
You can't post conmments that contain an email address.
Sounds like either there's no connection to an antennea or your tuner is dead. Our TV has the
same problem, so we took out the tuner and the games and dvd plays good still. So it's probably the tuner.
Depending on the unit you have if you have more than one input (mine has four HDMI, Computer, Standard TV, etc) you may need to be on the right channel or input. You should be able to bring up an On Screen Display that will let you make changes, You might want to try the Menu key on the remote to bring this up. If nothing else go to http://sanyo-av.com/support/ and find your TV and look at the manual.
Hi, You need a code to match with your TV remote.
The codes for the Ge universal remote for Sanyo are 0049 0097 0110 0004 0268 0012 0108 0180. You will have to try each code seperately untill you get one that works. Good luck.
Try pressing tv first on your cable remote then the video/source/input button on the cable remote. If there is no button on the television itself to switch video inputs a temporary fix for now is to connect the cable box to the video 1 female parts on your television. Buy the cables to do that if you don't have a spare set lying around. You can purchase a remote for your television with the model number from http://www.replacementremotes.com or even a Sanyo remote from a thrift store should be able to allow you to switch inputs.
A POSSIBLE solution. I have the same stet...got it used, but it's in good condition.
It was stuck on a channel. I went iinto the menu and fiddled with the channel programs and "deleted" the channel and now I can freely change channels.
By the way, I could use a manual for this ...got one?
