I followed the directions to run water through the coffee maker. When I plugged it in and turned on switch it did not work at all.
SOURCE: Draws about one cup of water then turns off
I was getting this too. I checked the manual and it recommended decalcifying the machine to clean out the mineral deposits that collect from the water used. I gave it a try, just using vinegar and following the instructions.
So far it's working great, I suppose it makes sense because I was worried there was a problem with the pump that it wasn't able to **** all the water out of the reservoir. But if the tubes are obstructed due to mineral deposits, it is too hard to get all the water and so shuts off thinking there isn't any left. You can find the manuals online @ http://www.mrcoffee.com/InstructionManuals.aspx
SOURCE: Need Replacement pot for black Kit. Select. Dual Pot Coffee Maker CM-202
Select Brands
Kitchen Selectives
Select Brands
Customer Service Or Call 913-663-4500
To order replacement carafes for the CM-202 Dual Coffee Maker you have to call Customer Service at 913-663-4500 - This item cannot be ordered on line.
SOURCE: After the machine beeps "ready" the filter is still full of water
Make sure the lid is on the caraffe, or else it will not make the proper contact with the filter basket (and hence the filter basket will be forced into the closed position).
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
SOURCE: How do I drain water
If leave it for a couple of months without using it, later on when you will need to use it again it by 95% it will be stuck. Their many parts related with water , 2 pumps, valves, jet pasages that even one of this goggled with a sales part then the machine will need complete desaesemble manual descaled and put back together.
So I sugest to find a way so that the machine keep work atleast once a week or even lent to a friend istead of put it on the shelf for long time.
