Question about Mary Kay Satin Lips Lip Mask & Balm 3 Oz Each
What product can i use for black lips
I used to smoke ********* and I stopped and I have the worst black lips ever
    Sergeant:
  • 239 Answers
Use white or silver then use another color
Posted on Oct 07, 2012
SOURCE:
My 2005 chevy malibu smokes when im sitting at alight and worst when i pull off
smoke color ----white like steam is coolant going to need to check coolant -oil-plugs etc possible head gasket ----blue smoke is oil gaskets -piston rings etc ---black carbon need tune up
Jun 11, 2018 | Cars & Trucks
What is the coldest winter weather can you smoke outdoors
Hi Sandra:
I would recommend not smoking at all, but if you have to, when your lips freeze and the cigarette falls out it would probably be a good idea to consider stopping.
Jan 01, 2016 | Grilling
Why smoking is injurius to health and in which of our body smoke is effect.
Cigarettes have multiple dangerous toxins that you ingest when smoking, the tar builds up coatings on your lungs that damage cells, they cannot repair the damage and become leather like and fatty making it harder for your body to process oxygen, cigarettes contain multiple poisons including cyanide that also damage cell structures, but the worst thing is it damages the heart and ventricles, narrowing arteries restricting blood flow. Cigarette smoking is also directly linked to numerous aggressive cancers that thrive due to damaged cell structures. I am a lifelong smoker and cant stop, I wished I had never started, so if you have a choice dont smoke.
Aug 01, 2014 | Health & Beauty
Citroen dispatch
Had the same-problem with the peaugot 807 giving out black smoke, I was fueling at morrisons regular was told to change petrol pump so I start using shells and the black smoke stopped compeletely. Try using a different petrol pump if that dont work than take it to the workshop.
Jun 02, 2013 | 2006 Peugeot 604
My nissan terrano emits black smoke and uses a lot of engine oil
either the valve stem oil seals have gone which means oil is trikeling into piston thats causes black smoke or worst case oil rings on pistons gone but the smoke will have a bluey tinge to it also may just need a service and tune up hope this helps ivan
Oct 02, 2012 | 2005 Nissan Terrano 2.7
When first stating blows out black smoke then stops
the black smoke indicates the car upon start up is rich,getting too much fuel,then it gets burnt up that it stops smoking.have the fuel system cleaned as dirt in the injectors may cause the fuel to leak after shut down,like a flood condition.also have the fuel pressure regulator check it may not be maintaining fuel pressure at the correct pressure,too high of pressure.
Nov 18, 2011 | 1999 Ford Escort
Car overheated,big boom under hood,black smoke out of back,speedometer dropping,oilpressure dropping and then car died. 94 eagle talon 5 spd
The engine has seen it's final days of providing secure and unproblematic performance. Where there is smoke, there is fire. overheating is the worst thing that can happen to an internal combustion engine.
Nov 27, 2010 | 1994 Eagle Talon
Smoke is coming out of the tail pipe even when the car is at driving temp. The smoke is not black
is it a bluish grey color smoke? if so then your motor is burning oil. you will need atleast a ring job to solve this.
is it a white smoke? if so then it is evaporating water, whish could be any number of things the worst being a possible cracked head or blown head gasket. or it could be something as simple as moisture in your muffler evaporating.
check your oil and coolant level, check for milky looking oil.
hope this helps, have a good day.
Jan 27, 2010 | 1997 Ford Explorer AWD
I have a 2003 F-350 6.0 diesel and there is the smell of antifreeze when the engine is warmed and been driven. I changed out the coolant tank, cap and checked the heater coil but it is not leaking nor is...
IF it is a Head gasket leaking into a cylinder you wouldent see smoke you would see white steam coming out the exhaust tail pipe and you should get temp creeping up as the further you go and by wrights you should be getting a missing in that cylinder as you cannot {run on coolant but you can on diesel}, but if you find its the coolant getting either in through the seal under lip on liner or head gasket leaking in coolant but will get a lot worse before getting better as only needs a hair crack to cause your problem..
Sep 06, 2009 | 2003 Ford F350 Super Duty DRW SuperCab
Saab 93 2001 - kicks out white smoke when started then drives ok until it gets to certain temp then starts miss firing and kicking out smoke
is car consuming any antefreeze? does the temp fluctuate? on worst case, you could be looking at poss. headgasket problem white smoke is usually antifreeze. black smoke is fuel, and gray smoke is oil
Nov 30, 2008 | Saab 9 Cars & Trucks
Mary Kay Satin Lips Lip Mask & Balm 3 Oz Each Logo
121 people viewed this question
Top Mary Kay Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Mary Kay Health and Beauty Expert? Answer questions, earn points and help others
