Copy from HDD to disk
How can I copy from the HDD to to a disc
  • 1 more comment
  • Tess Oct 10, 2012
    Add a CommentU
  • Tess Oct 10, 2012
    Hi Jeff. Thanks for your reply. I'm after to copy programmes saved on our Panasonic blue ray/DVD player.
  • jeff rollins Oct 10, 2012
    see a specialist. most likely you won't be able to save from a player to a computer unless your disc wasn't finalized then nothing can be saved.
    Sergeant:
  • 239 Answers
Right click send to...but not everything can be copied
Posted on Oct 07, 2012
SOURCE:
The HDD of my Acer Aspire 5102WLMi got broken. I bought a new one, partitoned it, load the D: drive with Acer stuff from backup, mounted it in the laptop and started this with the recovery CD. This...
@hellepie
The HDD interface on this machine is a PATA so BIOS shows the correct interface as IDE 0. Upon loading up the recovery disc (I'm assuming it's a good condition genuine Acer recovery media), what it does is that it re-images the HDD to the default file system and automatically occupies the full partition of the HDD so if you have already re-partition it, the problem might lie right there. Try to do the following:
1. Erase all partition on the new HDD that you have purchased and format it with NTFS and try to load the Acer recovery discs again.
2. If that won't work, try to use a retail copy of Windows and check if it fully install Windows. If it does, try to create a duplicate copy of your Acer recovery discs, it might just be faulty and try again.
Good Luck.
Sep 04, 2011 | Acer Computers & Internet
LG RHT498H recorder will not recognise new dvd discs to record to could you help me with this problem
i want to copy from the hdd to dvd but what i want to copy is to long for one dvd at good quality can i record to more than one disk. lester
Jan 27, 2011 | LG RH177 DVD Recorder/HDD Recorder
Error : 10-FC12-0570 when i try to reinstall with the cds
Error 10-FC12-0570 on Toshiba satellite This error message means that the recovery utility was not able to read the data from the disc correctly, or wasn't able to write it to the hard drive.
The problem could be with the disc, the CD/DVD drive or the hard drive.
Solution:
Try copying the second disc using another system. If it's impossible: order for a new disc. If you can copy it, try using the copy to do the restore.
Try using a third party disk checker to verify the problem, is or is not, with the hard drive.
The best way would be to load the Windonws Vista discs, format the pc and reinstall.
(Vista Recovery Boot Cd is available free by Microsoft). Download it burn the Image .iso and run that disc. That disc will not restore the OS: run diagnostics on the HDD; once disk check is completed and repaired, proceed with the Recovery disks that you have.
Nov 22, 2010 | Toshiba Satellite A215-S7422 Notebook
If hdd is correpted then how to formate a pc... it is showing that check disc; hdd correpted how to get over it
Copy all the files that you can to some other device (external disk-drive, or USB memory-stick), and then "reformat" the disk-drive, and reinstall Windows.
Jun 11, 2010 | Computers & Internet
Can you copy from a blu ray disk to the hdd
I think you need Leawo Blu-ray Copy to help you.
Leawo Blu-ray Copy is a one-click smart tool for Blu-ray HD video fans to copy and backup Blu-ray discs to hard disk and DVD discs. It incorporates advanced replication technology that allows you to copy Blu-ray discs from various origins to the formats of DVD-5/9, file folder, ISO image and even 1:1 disc duplication for storage.
Free download it in here: http://www.leawo.com/blu-ray-copy/
May 12, 2010 | Panasonic DMP-BD30K Blu-Ray Player
I have lost the driver disc for Everio HDD
connect vcam to pc via usb cable: then copy thru windows explorer
on pc bottom left: click START>>then click My Computer; win explorer opens
on the right portion you'll see>> Hard Disk Drives, etc.;
then >>Devices with Removable Storage- the location where most probably you'll find your >>hdd vcam- w/some ID- brand?
Double click on it, locate your video/picture files and copy/paste to >> my Documents/my videos (my pictures?) located above Hard Disk Drives.
Import the desired video files to video editing software
Jul 25, 2009 | JVC Everio GZ-MG335 HDD Camcorder
I am coming up with error 10-fc12-0570 on the toshiba satellite a215-s7422 i used the both recovery disk and this was the error code
The error message is telling you that the recovery utility was not able to read the data from the disc correctly, or wasn't able to write it to the hard drive. The problem could be with the disc, the CD/DVD drive or the hard drive.
but usually error 10-FC12-0570 is pertaining to a bad HDD or memory
First, try copying the second disc using another system. If you can't copy it, order replacements from Toshiba Customer Assistance: 1-800-457-7777. If you can copy it, try using the copy to do the restore.
You can try using a third party disk checker to verify the problem is or is not with the hard drive. But since the system is under warranty, you're going to have to arrange to have it repaired anyhow, so it may not be worth the effort to verify whether it's the hard drive or CD/DVD drive. It's probably not the CD/DVD drive since you got all the way through the first disc. Contact a Premier (not regular) ASP for service from here: http://pcrepair.toshiba.com
The best way would be to load the Win Vista discs n format the pc...and reinstall...iam telling this because u have a tried the recovery disk as well....
I know most users will not have the Vista CD with you but the Vista Recovery Boot Cd is available free by Microsoft just google...
Download it burn the Image .iso and run that disc. Since that disc will not restore the OS all it does it lets u run diagnostics on ur HDD and allows u to install the OS. Once disk check is completed and repaired, proceed with the Recovery disks that you have.
thank you
have a nice day
Jul 08, 2009 | Toshiba Satellite A215-S7422 Notebook
I've got BIOHD-3 NO BOOTABLE DRIVE (HP Diagnostic test)
if it cant detect ur HDD ... then check for jumper settings. ...
Jul 04, 2009 | Computers & Internet
Dubbing from HDD to DVD disc
I beleive you can only dub from hdd to disk,
Try formatting the disk first.
good luck
Norm
Apr 03, 2008 | LG RH177 DVD Recorder/HDD Recorder
Can't record onto disc
press dub on your remote, it will open the menu choose your programme you want record then click on hdd to disc.
Mar 02, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Ekse
