Plastic watch band broke, cannot find replacement that will fit
Try this link below
http://www.sportline.com/contact-us/contact-info.html
SOURCE: My 433lsl black band broke. I can not find a replacement broke
order a replacement band directly from skagen its only $25
http://www.skagen.com/service/home.fx
SOURCE: wrist band adjustment on a fossil watch
Just take a tiny little jewelery screw driver small enough to fit in the pin hole and tap it with anything that you can find. Then pull out other end. Look for arrows indicating which way to remove pin and go in that direction Some pins are like a hairpin and have a split at one end. Replace solid end first opposite of arrow direction. If there are arrows in both directions on the same link; like Fossil for instance, that means that it doesn't matter which direction the pins are removed or replaced. They are solid and they can go back either end first. It's easy. To get the pin in all the way I just used the little screw driver and tapped it in. Good luck.
SOURCE: Sportline watch setting time???
With the watch in time mode, press and hold the mode button for 4 to 5 seconds until it beeps and the digits start to blink. Then press the mode button again to advance through each setting. When finished press and hold the mode button to exit the setting mode.
SOURCE: replacement acrylic watch band
I posted the other same request...all I've been able to find is ceramic replacement bands, and nothing clear. These run about $200.00 and for that price we should just replace the watch with a "Toy" which it is copy of...
SOURCE: replacement band
mcdevito75 here, Look for a small watch repair shop in your area, to save on costs, new band and labor.
