Ovens Logo
Anonymous Posted on Oct 06, 2012
Oven doesn't work
Broiler works but bake feature does not
Anonymous
Level 3:
  • Master 963 Answers
  • Posted on Oct 07, 2012
Anonymous
Master
Level 3:
Answers
963
Questions
0
Helped
489393
Points
1500
This is not a problem with your dryer. Resubmit.
All the lights and buttons work/sound on control panel. Broiler oven works but baking element not working. Replaced baking element with new, but still doesn't work. Convection fan works, light works,...
Manufacture and model would be nice ohm out the bake element might be open some are in the oven cavity others are hidden below the lower oven plate and have to check from the rear by removing back cover in the bake mode the broil element element cycles on/off thats why you have some heat.
Feb 10, 2014 • Ovens
My oven doesn't heat up
It could be the switch or heating element
It's a Model JJW8530CAB. The baking element
Are you having any issues at all with the display at all? Did this start out of the blue or did you have a power outage or anything else?
2answers
Oven doesn't work (bake nor broiler) checked both heating elements there fine whats next?
With out a model number I was unable to look up any specific information.
First I would look for a thermo fuse on the back side. If you model has one it may be bad. If it's a older oven with a mechanical clock make sure the clock is not set to timed bake.
Aug 03, 2011 • Ovens
I have a roper free standing stove. Everything seems to work except the oven. When I turn the thermostat to broiler it works but doesn't when I turn to oven
next time send the model number and say if it's gas or electric?if it's gas you have a bad bake ignitor,if it's electric you have a bad bake element
Apr 22, 2011 • Ovens
Bake feature on oven won't work ignition light glows but flame won't spark. broiler works
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
My Kenmore oven wont ignite. The broiler works
The problem is your bake ignitor. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The bake and broil oven features each have their own separate igniters and operate independently of one another. That explains why the broiler still works. They are, however, fed from the same gas source. So...the logical conclusion would be to replace your bake igniter (the no glowing is usually a dead give-away).
Replacements can be purchased on line at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. Prices can vary amongst sites, so shop around for the best price. The sites I provided to you, I found, tend to offer the best service and prices.
If you have questions along the way, or require addtional service, please let me know. I hope you find this information helpful.
5helpful
Whirlpool SF315PEPW1 oven/broiler won't work
whirlpool range/over the broiler works the oven does not warm up. what is the solution.
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
