Roman Disney Mickey & Friends "Around The Tree" 17-Piece Christmas Train Set Logo
Anonymous Posted on Dec 30, 2008
Train plays music but won't move
The train will make all the sounds but does not move. I changed the batteries but no success. Thanks in advance for your help.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 30, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
948
Points
I exchanged it for a new one:-)
2answers
Train won't move. The sounds work great, and it used to move, but now it doesn't.
the sound runs from a different battery source, you'll need to remove the screw on the fron t of the seat and then lift the seat up and charge the battery with the supplied charger
Perego Choo Choo will make noise, but won't move
the sounds are run off of a different battery source, check the battery under the seat and make sure that its connected
Thomas train shows as fully charged however when trying to use it, music starts but then a clicking noise and train doesnt move
the music is run by three aaa batteries so that will work no matter what, did you reconnect the battery to the vehicle after charging it
Music will play but train will not move or do any other function
I'm not spending money for asking if there is a button to push to make the train go around the track! That is a simple "yes" or "no" answer! I can promise you that I will not buy another product from your company and will tell all my friends about my experience with your product!
Spaldingsr
Thomas the Train Ride on Train only goes backwards
Check the battery. It sounds like you have it in, backwards.
Sep 17, 2009 • Toys
1helpful
Thomas train charge battery has music and sound effects, but does not move?Does it need a new motor
It might need a new wire connection to the motor.
I would contact
http://www.shopjandl.com/
They help me with my ride on toys.
hope this helps
5helpful
3answers
Peg Perego Thomas Train Track Rider
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
9helpful
9answers
I cannot promise that this is the problem, but this is where mine was broken, and you may be able to fix yours this way.
I was able to remove the plastic around the tender and access the motor. Using alligator clips, I was able to connect the battery directly to the motor, bypassing the circuit board. The motor functioned, therefore the only component that seemed to be defective was the circuit board, located behind the speaker in the engine unit.
As far as I know, the only place to buy a replacement circuit board is from www.tigerimports.com. Search for part number MEVA0024. Cost is around $15 + shipping (around $6 or so).
I should be receiving this part by the end of the week and will report if it fixed the problem.
Thanks for using Fixya. If I didn't help your situation, please DO NOT label this advise as "inappropriate".
Mar 12, 2009 • Toys
Top Roman Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Roman Toy Expert? Answer questions, earn points and help others
