SOURCE: installing electronic transformer with 3 way touch dimmer switch
Consider using a MAELV-600 and a MA-R. The MAELV is rated for 600W Electronic Low-Voltage. The MAELV will require a neutral wire connection.
www.lutron.com/maestro
SOURCE: humming inside the switch
Is it connected to a fan motor also? - most dimmers are for lights only - if there is a ceiling fan connected you may experience a humming sound from the dimmer
SOURCE: A fixture on a Lutron Maestro dimmer switch stopped working.
This dimmer was not made to dim a load smaller than 40VA. That halogen bulb would only have been 20VA or so.
http://www.lutron.com/cms400/PageBuyNow.aspx?id=16977&mn=1815
I think that when your bulb burnt out, the dimmer over-volted the transformer and smoked it. That said, I think you have a fixture problem and, possibly, a switch problem, too.
SOURCE: newly installed Leviton dimmer switch humming at the switch
You'll need to install an electronic dimmer, like a Maestro. Otherwise, you'll have to live with the hum.
SOURCE: Short in light fixture and Lutron switch no longer
The short blew the Lutron. Replace it.
Testimonial: "Just what I thought. Thanks"
