I have read instruction manual of hp. all of my printer lights keep flashing.
I have tried to turn it off. it wont turn off. so I unglugged it and then it turns itself back on and all lights keep flashing.
I was printing in borderless photo mode and did what they said in the manual to do to fix prob. but lights keep flashing and printer won't turn off.and if I try to print something it won't print.
thanks
HP deskjet 5150 printer
Remove all ink cartridges. Then unplug your printer and plug it in again
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
SOURCE: printing from iphoto - photos are not 4x6 and not borderless
wat pc do u have? are u using mac? if ur using microsoft try these:
go to ur printer and faxes - right click on ur hp printer icon - select preferences - select printer shortcut tab - select the appropriate size - the click ok. that should solve ur problem
SOURCE: HP C6180 won't print borderless photos
Also had ongoing problem of paper jams printing PDF files, but not when printing any other files. Solved both problems by uninstalling and reinstalling printer driver.
SOURCE: How to check ink levels on deskjet 5150?
Download the instruction Manual for the HP deskjet, model 5150:
http://h10025.www1.hp.com/ewfrf/wc/product?product=304431&lc=en&cc=us&dlc=en&submit.y=4&submit.x=7〈=en&cc=us
SOURCE: flashing on/off light on hp deskjet 3520 printer
Introduction
The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused.
NOTE:
The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking."
Blinking lights
Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first.
Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution.
Issue: Power light is blinking
Solution
Close the cover.
Cause
Printer cover is open.
Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper.
Solution
Cause
The printer has difficulty picking up label media.
Solution
Follow each of these steps until the problem is resolved:
Cause
There is a paper jam.
Solution
Cause
There is a problem with a print cartridge.
Solution
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
