Question about Jaeger-lecoultre Reverso Classique 2798120 Wrist Watch
Winder has broken off jaeger-lecoultre watch
My winder has dropped off my watch and I cannot find it. Is is possible to have a new winder inserted?
  • 43 Answers
Yes, but for an authentic Jaeger-lecoultre watch it will be very expensive.
Posted on Jan 05, 2009
SOURCE:
Steinhausen tm-478 single watch winder how it worcks
Watch Winder Setting & Instructions for Executive Collection
Jared Tracy
posted this on March 30, 2012, 2:44 PM
  • inShare
  • There are four modes for our Executive Collection of Watch Winders (TM and SM series):
    Mode 1 (both switches with the O pressed in): rotates for 180 seconds on then 12 minutes off.
    Mode 2 (first switch with the O pressed in, second switch with the I pressed in): rotates 180 second on then 15 minutes off.
    Mode 3 (first switch with the I pressed in, second switch with the O pressed in): rotates 180 seconds on then 18 minutes off, then 180 seconds in the opposite direction.
    Mode 4 (both switches with the I pressed in): rotates 180 seconds on then 24 minutes off.
    For switching winding direction:
    I pressed in will wind clockwise
    II pressed in will wind counter clockwise
    Neither pressed in will turn the winder off
    *Please note that the CW and CCW settings do not apply when the winder is set to Mode 3 as this mode winds in both directions.
Apr 10, 2014 | Steinhausen TM-478 New Single Watch Winder...
The watch seems to stop when I wear it - fine timekeeper if not worn!
The only way that makes any sense is if there is something loose inside the watch possible the battery plate or battery are moving when you are moving. The back will need to be removed and the battery plate checked. You will need to have the watch checked at a jewelry store or watch repair shop. Thank you i hope this helps a little !!
Oct 24, 2011 | Jaeger-lecoultre Reverso Duoface 2711410...
I have jlc movement 450 with dial but case is missing
cousinsuk.com choose branded watch parts, select the brand and search. They are in England but I use them all the time, you have to go through there little signup procedure but whatever it takes, right?
Feb 12, 2011 | Jaeger-lecoultre JaegerLeCoultre Master...
Hello, I was watching shopnbc and heard salesman describing winding the mainspring for automatic prodiver which I attempted as described. Screwed myself out of a working watch (lol)! Can I fix myself?...
the crown/ winder has three positions
unwind the crown nad pull out slightly is for winding the watch.
position two pull out slightly more it should adjust the date .
and then finally position three fully pulled pout will adjust the time.
If it does not do this then is possibly the winder pivots broken/faulty.
Dec 05, 2017 | Invicta Watches
I cannot wind the watch, it will not wind up. What is the approx cost to repair.
Just the stem - is about a $40 repair.
If there is clockspring damage - you're looking at $75ish
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Jaeger-lecoultre Reverso Classique 2798120...
The moving mechanism inside gets stuck and i have to violently sheck the watch to get it lose and start working
mcdevito75 here, Sounds like you need the watch serviced, specially if not so in 2 years. Check the repair service directory here at Fix Ya, bottom of the page click on repair service directory then watches.
Jun 25, 2010 | Jaeger-lecoultre Master Compressor Memovox...
Problems with setting the date on this watch
mcdevito75 here, It does seem to be a hard way to set the date. I would imagine to you have stem and not buttons, Try this slip your fingernail just under the stem (winder) and lift the stem to it"s first position, now turn the stem either toward or away from you to change the date easily.
Jun 21, 2010 | Jaeger-lecoultre Master Compressor Memovox...
Vintage 1940. Doesn't run. Numbers on back of case illegible. Dirty, but intact. What have I got?
It might be worth having the back of the watch removed to see if there is anything engraved on the movement.
You might find that cleaning the watch gets is going, although the advice of the watch repairer should be asked for on this, as it might be very worn and in need of new parts which are unlikely to be available.
If it works and there is information on the movement, you might be able to get some information on the watch from the maker. Visit their web site (www.jaeger-lecoultre.com/) and make an inquiry, giving them all the information that you have.
An interesting problem!
Good luck.
Jan 24, 2010 | Jaeger-lecoultre Watches
Small dial on the watch face that counts the minutes won't return to zero. It still functions but when the 'reset' button is pressed, all other dials but this one return to their zero setting. Watch is a...
Check in the instructions if there is a way to re-sync the hands. For some models of watches the hands are able to be calibrated.
It is also possible that the watch has a problem. Either the dial hand is not properly seated on to its axel, or the drive gear that is under the axel skipped a tooth. You will have to find someone who can service watches to fix this for you.
Jerry G.
Nov 21, 2008 | Jaeger-lecoultre Reverso Classique 2798170...
Jaeger-lecoultre Reverso Classique 2798120 Wrist Watch Logo
517 people viewed this question
Top Jaeger-lecoultre Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Jaeger-lecoultre Watch Expert? Answer questions, earn points and help others
