Tell me how open and see the internal battery if there is, and actually the problem because this device cant charge or come on. Thank you
SOURCE: bluetooth ear piece
blinking red and green means the headset is in pairing mode and ready to be connected to your phone. This means it is either the first time you have paired the headset or you have depressed the volume +/- buttons simultaneously for more than 5 seconds. If your phone cannot find the headset, it may be a compatibility issue. Try pairing the headset with a friends phone, possibly a sony ericsson. Good luck.
SOURCE: can't charge the hbh-608
The problem is the connection points. Take a pecil reaser and rub it back and forth across the coper strip. Do this to both the earpiece and the end of the charger chord. This is what fixed it for me.
SOURCE: sony blue tooth hbh-pv703
you need to press and hold the buton until the light stays on to get into pairing mode, when on, go to your phones bluetooth settings, search for bluetooth devices, then when it finds the headset a code will be requested, this is 0000, enter this and the light will flash intermittently telling you its paired with your phone.
SOURCE: i have a HBH-PV705 bluetooth headset that is
I am having the exact same problem with my PV705! I've followed all the directions and tried charging it numerous times but still nothing.
