Is this a USB connection? Try a different USB port. If it still won't work, go to: MY COMPUTER: PROPERTIES: DEVICE MANAGER. See what it says in there about USB DRIVERS and HARD DISC DRIVERS.
Is your drive external or internal? If it's external, see what happens when you plug it into another computer. If it is internal, see if you can reformat it using the operating system's reformatting program by paying close attention the information the computer is trying to tell you.
A computer that is running Windows XP cannot detect a USB flash drive, an Apple iPod, or an external hard disk drive
To fix this problem, delete the UpperFilters registry value and the LowerFilters registry value. These values may cause access problems. (from Microsoft website)
Hi AHPretorius:
Do you have access to a Windows XP machine that you can try to use the drive with? Maybe a friend's computer? I would try using it with such a system and run chkdsk on the drive to make sure that the partition is healthy; otherwise, you might want to buy the DiskInternals program that may be able to help you revive the partition.
http://www.diskinternals.com/partition-recovery/
Please feel free to ask follow-up questions in a reply here.
Thanks for using FixYa and Happy New Year
Here is the Procedure for Connecting External Drives to Computer.Several brands of computer does not recognise external drives when connected to USB expansion slots,and Slots of front panel,So connect your Ext HDD to back side onboard Slots.Because there is a lack off USB power surge voltage to detect a large capacity exteral drives.Some time it is does not recognise by many computers,when USB power surge voltage is low.
I think it helps,
If you find any difficulty post a feed back we were happy to assist you
well try running install new hard ware! xp is really propritory !!l it doent like to be put on different machines because it wants oem ## an i think it notes ur machine id # an when u move it to different machine it dont work!i move hard drives around from several machines! an it seems if its xp u have to reinstall xp on the new machine!
if its melinum or 2000 u have no problem! xp is a weird animal! well good luck an merry christmas!
Hi Yodel,
Plug in the Book Pro.
Then ff you RIGHT mouse click on MYComputer
then select PROPERTIES and then click on
HARDWARE then DEVICE MANAGER
Do you see any exclamation marks?
If you do, click it with the mouse and select remove. Then unplug the Book Pro, restart the pc and then plug the bookpro back in.
Let me know what happens.
