Parrot MINIKIT Bluetooth Hands-Free Kit Wireless Headset Logo
Posted on Dec 29, 2008
Green and Red Lights on my Parrot minikit slim/chic are flashing
Both the red and green lights on my Parrot minikit slim/chic are flashing continuously. Tried the reset on the back panel, no joy.Any help would be appreciated.
  • 5 more comments
  • Anonymous Jan 06, 2009
    I have the same problem... but both lights are ALWAYS turn on, not flashing.
  • AdmiraNelson Jan 07, 2009
    I have the same problem and have taken one unit back after one week in use with this problem.  It seems to occur when there is a conflict in synchronization or communication and the unit freezes.
    It has cleared itself a few times - not sure how but my strategy this time is to let it run out of power and see if it comes back.  A real annoyance as it is a neat unit.
    my only other complaint about it is when it selects a contact from the voice prompt it does not give an option to confirm that it has selected correctly and sometime gets it wrong but goes ahead and dials anyway and you need to quickly cancel and start the process again.
    Any feedback on how to fix our issue?
  • Anonymous Jan 09, 2009
    both lights flashing just going to let power run out and see what happens
  • Maravillas Jan 11, 2009
    I have a Parrot Minikit Slim, both lights are on now. The machine does not do anything else and, of course, doesn't work at all!
  • Anonymous Feb 06, 2009
    Same problem - both red and green lights come on and unit does not work - instructions mention reset button on the back - but there isn't one!!!!
  • Anonymous Mar 29, 2009
    both green and red button are flashing and I can't get it to stop
  • Anonymous Mar 15, 2014
    parrot minikit change language
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3286
Points
Spoke with Parrot, was told that the batt had been left to run to low and I had tried to use it.
let the batt run right out and all will be ok.
I know put on charge veryday and have to had the problem again
2helpful
HOW CAN I PAIR MY I PHONE 4
• Press the red button and the rotary button at the same time for three seconds. The green and red LEDs both flash. The Parrot MINIKIT is visible to all Bluetooth devices for three minutes.
• From your iPhone, go to Settings > General > Bluetooth. Make sure it is On. In the device list select MINIKIT
• Enter 1234 on your phone when prompted.
• The device sounds a beep when connected.
18helpful
My parrot minikit keeps saying memory full when i try to connect to my phone?
you have to erase the minikit memory by pressing red and green button simultaneously for 5 seconds until you hear a voice saying "memory erasing in progress please wait"
How do I pair my PArrot Minikit to my mobile phone?
Press and hold both the red and the rotary buttons for some 3 seconds, until the indicator light flashes alternately in red and green. It is in pairing mode now, thus visible for other devices, for the next 3 minutes. Then, make your phone's bluetooth application search for new devices. After a little while, your car kit should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '1234'. If the pairing process is successful, the car kit should sound a beep. By the way, if your car kit's user guide happens to be missing, feel free to download it from this location. You will find many details about settings for your car kit there.
Please, let me know if I can help you any further. Regards, Carlos
7helpful
Pair parrot minikit 1.03C with my iPhone 4
11helpful
2answers
Clearing parrot minikit memory
Just press on the green and the red buttons at the same time, you will have erasing memory in progress, please wait. And then please pair device.
4helpful
2answers
A Parrot mini kit slim. I can turn it on. Don't know how to turn it off. Is it necessary to do so?
If it's a Minikit Slim, did you try to reset it ? To do so :
1. Press simultaneously the jog wheel and the Reset button located at the back of the Parrot MINIKIT Slim / Chic.2. Release the Reset button.
> You can now release the jog wheel.
Important information for those of you who have this problem (the kit freezes and buttons don't work anymore, even the reset).
Thisproblem may appear when the battery level is too low.Parrot has fixedthe problem now, below is the procedure to follow for those who stillhave this problem :
1- Leave the Minikit slim in charge for ~30min
2- The reset becomes functional :
- Press the rotator button,
-Press the reset hole, keeping the rotator pressed ( on the back, with apaper clip ), and then release the reset button first.
- Release the rotator
The Minikit slim should be functional...
3- Make an update with the version 1.06 ( install the PSUT http://www.parrot.com/uk/support/downloads...)
/!Attention : people who have the problem and already have version 1.06need to update again (changes have been made on version 1.06 )
I hope this helps and good luck.
9helpful
3answers
Parrot minikit slim frozen
Hey people! Read the full owners manual on the web.
Press the jog wheel and reset button at the back at the same time.
It resets itself.
By the way, I've thorn down every single piece of the slim kit, I unscrewed about 8 screws, and I suggest you do not do the same ever.The soft pad is self glued and now it does not stick back as before.
1helpful
Parrot minikit
Most probaly, yes. I don't have an iphone to either confirm or deny it, but, I can see no reason at all why they would refuse to pair to each other. To do it, press and hold both the red and the rotary buttons for some 3 seconds, until the indicator light flashes alternately in red and green. It is in pairing mode now, thus visible for other devices, for the next 3 minutes. Then, make your phone's bluetooth application search for new devices. After a little while, your car kit should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '1234'. If the pairing process is successful, the car kit should sound a beep. By the way, if your car kit's user guide happens to be missing, feel free to download it from this location. You will find many details about settings for your car kit there.
Top Parrot Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Parrot Radio Communication Expert? Answer questions, earn points and help others
