JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
Heather Millhorn Posted on Oct 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you fix the convergence on a 2003 42 inch big screen tv?
Jerry Kramer
Level 3:
  • JVC Master 3,933 Answers
  • Posted on Oct 05, 2012
Jerry Kramer
JVC Master
Level 3:
Answers
3933
Questions
Helped
882317
Points
12076
In the menu on the tv setup you should find a test pattern that can be displayed for converging. In that menu there may be an auto converge which is much easier. If not, with the patter up you will have to manually converge the individual guns in the tv with the back off. There are adjustment knobs or screws for focusing the guns.
4helpful
Its a 2004 61 inch big screen projection tv and the subject on screen has three colors outlining it green red blue on the outer portion of subject on screen
Tv have a problems known as a convergence pictures problems,it is dead.Tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must be replaced to repair it.To solved tv pictures convergence problems.The shop will cost u like $300-350 for parts and labors.
I have an akai 50 inch tv. I have a darker area on the left side of the screen about 3 inches wide. I replaced the bulb but the problem is still there. Any idea how to fix it. Its a projection tv.
Convergence is dead.Replaced the 2 convergence ICS,should solved this problems.Try website Tv repair World.com to buy a Whole convergence board to replaced.Samsung/Akai use the same convergence board.
2helpful
Toshiba Big Screen Tv Has Bad Colors
this is a rear projection tv not lcd the color is off because the convergance chips are bad take the board out that has the tow stand up chips attached to heatsinks out order the stk number search for on google then take a om meter check all the resistors aroung the chips replace them also you must be a excellent soilder person or a tech to install and remove these chips
Different Kind of Convergence Problem - RCA 52 inch
The FL231 fuse is dead.There 3 retangles squares the one in the midle is dead near the right side of the FBT high voltage transformer.the big plastic block with a red wire hook a cap to ur CRT.
1helpful
Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
I HAVE A RCA 52 INCH SCREEN WHILE I WAS WATCHING IT THE SCREEN WENT TO A CURVE SHAPE AND THE COLORS ARE GHOSTING. MODEL #R52WH74.WHATS WRONG
you have a very common tv projector problem bad convergence
you need stk ic big chips on large silver heat sink.cost to fix from tv shop is around 250 to 400 depends who you get part are only 45.00 dollars
I hope this helps good luck
doctor video leadingedgelectronics since 1987
I have a Mitsubishi 65" HD-1080 big screen tv. Today when I turned it on it had a red shadow all over it and the red tube was off by about an inch. The TV has an automatic convergence function that I...
Convergence ICs need to be replaced. post the model number and I will list which ICs you need and where you can get replacements with free installation instructions.
My Hitachi Ultra Vision 50 inch big screen (projection) tv has a ghost look around everything. Please help me and tell me how to fix this at home. Thank You, Dustin Kellems
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Projection red is above other colors
Look in your menu for something called "horizontal static convergence" or just "convergence". Adjusting this will align all three tubes electronically. If physical adjustment is needed, then you have to do this manually inside the Tv. keever
Tilted tv screen
The complete convergence for the Philips projection sets usually requires a clear plastic overlay which fits over the screen and has many precisely spaced black dots. The remote is then used to enter the service mode and converge all 3 colors onto the dots, and then the settings are stored in an EPROM IC. This should only be done by someone with experience with the Philips sets.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
