I have cleaned every part of my Roomba without any problems.
Over a year ago my dog had a serious case of the runs. Before we got home my Roomba i780 equipped with it's millions of dollars worth of R&D effectively spread said dog "business" evenly to every single square inch of hardwood floor and carpet in my house. It was quite a scene, and cost me a pair of $300 Ugs to get my girlfriend to clean it up.
Needless to say I took it completely apart and washed every single component. Actually I washed each component several times because the smell lingered.
While it says in the instructions not to use cleaning solutions on the components I can say that in my experience it did not cause any harm. Mine has been working for over a year since without issue.
I should add that prior to this happening I had cleaned the cleaning head module with fantastic many many times. I'm guessing yours is starting to accumulate that mm thick film of dirt. Just spray a paper towel with cleaning solution and slowly wipe it off. I have found putting a cloth over a screwdriver for "soft scraping" is good strategy.
Ok. What I would do is to disassemble the Roomba, clean both its wheels, Cleaning Head Module (including the gears) and the front bumper sensors. If after cleaning the front bumper sensors and same problem...you will need to replace the sensors. It's more than likely one or more of the IR LED are damaged.
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module.
If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
