Second hand works until it crosses over minutte hand and it seems to 'stick' and stops moving. stopping watch completely
SOURCE: The (second(s) Counter Stick has stopped
is it a chronograph model? If so, reset the chrono. If not, you are going to have to send it in to a repair shop or the mfr to repair it...probably bumped it hard
SOURCE: the second hand stop moving but the watch is still
The hands of an analog watch are often only press-fitted on the shafts (hour and minutes are tubular, seconds solid shaft) and the second hand has probably only slipped so it is no longer being driven. I suspect a watch-maker could reattach it for a small charge.
SOURCE: The second hand of my Tissot watch T870/970 starts and stops.
Hello!
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
SOURCE: Second hand doesnt move
Sounds like a job for Fossil!
Go to their web site "www.fossil.com" and at the bottom of their page is a menu which includes "store locator".
SOURCE: (cj1110.ba0576) Wrist Watch: the second hand on my tag watch is sticking for a ...
you don't have to change battery, as it was still at the right time. There might be some other reason that your watch behave like that. A test on the capacitor of your watch is needed, if this still strong then i suggest you should have your watch General Overhauled by a technician.
