Washing Machines Logo
AZIMUDDIN SHAIKH Posted on Oct 04, 2012
A.c. voltas package error UL - Washing Machines
Ammu kumar
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 20, 2018
Ammu kumar
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2455
Points
5
Md AkibB
Level 1:
New Friend:
  • Posted on Apr 23, 2019
Md AkibB
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2455
Points
Voltas package Ac 22 tr air cooled what is the error
Voltas Cassette A/C 2 ton. The indoor light is blinking 8 times. Problem?
What is the error code E8 on Voltas cassette AC unit?
An E8 error usually indicates a fan problem with the indoor or outdoor unit. An E8 error is usually cleared by power cycling both the indoor and outdoor unit by turning power off at the breaker. Be sure to check the indoor air filters are not dirty and blocking air flow from the fan.
Or
https://www.republicworld.com/technology-news/gadgets/voltas-ac-error-codes-list-know-the-meaning-of-all-these-error-codes-right-here.html#:~:text=F8%3A%20This%20error%20code%20shows,with%20the%20outdoor%20DC%20fan.&text=P2%3A%20This%20error%20code%20shows,the%20Compressor%20phase%20current%20protection.
What is the error code F8 on Voltas?
F8: This error code shows up only when there is an issue with the outdoor ambient temperature sensor. F9: This error code shows up only when there is an issue with the outdoor DC fan. P2: This error code shows up only when there is an issue with the Compressor phase current protection.
Mar 24, 2021
Voltas AC Error Codes list: Know the meaning of all these
https://www.google.com/search?q=Voltas+Cassette+A%2FC+2+ton.+blinking+8+times
My voltas spit ac showing E6 error just after installation
It is under warranty, bring the installation people back.
Voltas AC error code E6 fix - Check the voltage on the inside unit. Check communication signal wiring between inside and outside units for poor connections or an open wire.
Apr. 30, 2021
Voltas AC error code E6 explained: How to fix error code E6?
https://www.republicworld.com > ... > Gadgets
2helpful
2answers
F0 error code voltas split inverter ac
Hi my voltas inverter ac showing F0 what problem is there
2answers
1helpful
5answers
How to solve ul error code in voltas package ac
Sir my package Ac is .UL error code sir
Voltas inverter split ac showing e4 error code and got shut down after 5 minutes what is the solutions
My voltas inverter ac e4 error which is communication error.It works fine in sunny day but stops in night or rainy day and shows e4 error.
2answers
Solution for f6 code in voltas split ac
Indoor unit fan motor is defective - good luck
Read more: Voltas saplit ac not working error c ode in display f6? - F6 error code in split voltas air conditioners :: Ask Me Fast at http://www.askmefast.com/Voltas_saplit_ac_not_working_error_c_ode_in_display_f6-qna8442437.html
1helpful
3answers
Voltas cassette ac error codes
Voltas VRF indoor unit E0 error code sho
3helpful
Voltas vertis issue
Pls dont purchase voltas products. They don\'t give service in warranty period & don\'t want to listen to complaints.
Top Washing Machines Experts
john h
