When I plugged in the Metz MZ 57656 76-56 NiMH Battery to charge I keep getting a blinking red light. The battery is brand new just out of the box.
One of your cells is defective.
It maybe brand new, but we don't know how long it's been in the box.
You will need a DVM to troubleshoot the battery.
[email protected]
SOURCE: metz 6ct4 flash head
Are you still having problem with the flash not flashing? Use a DVM (digital volt meter) to measure the battery from the pack. Take the 6 volt battery out from the pack and measure it. A reading of 6vdc or greater is good. Also the for amp. of the battery. Alexander [email protected]
SOURCE: Metz 60 CT4
The Metz 60CT-4 uses Accu 60-38 4.5Ah @6V Pb battery.
Charging system is difference from NiMH battery.
Beside the voltage is only 1.2VDC per cell on NiMH battery.
Four cells will have a total of 4.8VDC.
If you got five (5) cells: 1.2 X 5 = 6.0VDC. Do not charge these cells with Metz. Use NiMH Charger for NiMH battery.
Alexander
[email protected]
SOURCE: Metz 45 ct5 flash battery pack wiring diagram
You can rig that fella up for a better power.
[email protected]
SOURCE: Have to manually reset constantly the Metz 76 MZ-5 with SCA 3202 unit.
have you try to use different batt pack..?
