The problem it has is the software seems to either have a problem or the mapping itself is the problem, if you bought the device brand new from a shop like halfords, then you will have the TomTom 1 year warranty, but you need your reciept for it to be authorised.
if you have done a back up of the device previously on tom tom home then you can format it and it may back up ok.
alternatively go into any Halfords or other store and speak to the specialists and they'll give you any info they can give.
SOURCE: tomtom go
Some files on your card got corrupted. This happened to me in meddle of nowhere. I had made a card backup before, so solution was to put the card into PC, format it , and restore backup. After that TOMTOM started working again. When I put the card into PC it didnot seam that enything was corrupted, so it must be some hidden file. From that time on, I bought additional card and restored it and now carry that card as backup if this happen again. If you did not make a copy or backup of the original card, you are out of luck
SOURCE: tom tom is not working
1: Make a full back up of your SD Card.
2: Delete your SD Card.
3: Install the latest update to your Device, you will need to log in to the Tomtom website, select on the support page, select on the 1st question ' Update , follow the instructions on how to download and install the Update on to your Device
4: Re-install your Backup. The only Folders that you will need to re-install are the Voice, Map and Zip Folders.
Thanks for the comments received .This TT does not have a removable card, and also wont connect to TT home, wants me to re format first.
