Question about Sony M2020 / M-2020 Microcassette Dictator and Transcriber
Sony m-2020 tape will not move in record or play mode
Tape does not move in play or record modes. fast forward and rewind work fine.
    Habit-Forming:
  • 54 Answers
Here's the manual of this recorder. You can take a look at it to see if there are any explanations regarding the error:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000033419.pdf
Posted on Feb 21, 2013
SOURCE:
I would like some advice on how to fix my sony tc161sd cassette recorder that does not play or fast forward
The unit needs belts and lubrication as well as other things that are seen in the repair of this older mechanism.
Oct 12, 2016 | Sony Audio Players & Recorders
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Dec 07, 2010 | Dictaphone 1740 Desktop Cassette...
Suddenly my Sony M-2000 Microcassette Transcriber will not PLAY. The tape will Rewind and Fast Forward fine, but when you push PLAY, it just beeps and won't move. Any ideas?
Just talked to Exec. Communication Systems. He said that the play motor is not turning (the rewind and fast forward uses a separate motor) and the problem is either the belt or the motor. They can repair them at $82.00 plus parts and shipping.
May 18, 2009 | Sony M-2020 Desktop Cassette Transcriber /...
Erasing recorded tapes
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
Apr 20, 2009 | Philips Desktop 720-T Desktop Cassette...
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Jul 02, 2007 | Sony Handycam CCDTRV118 Camcorder
Rewind or fast forward
Though not familiar with this model, VCRs of all sorts have an idler mechanism which drives the supply and takeup spindles. Either the idler is somehow defective and slipping, and, assuming this idler is belt driven, the belt may be slipping just enough to cause a no Rew/FFW condition. If you had access to a test tape jig (a clear dummy tape, which allows a tech to view what is happening in the area normally obscured by the loaded tape), this might give a clue as to what is happening. On alot of machines, a problem with Rew/FFW would also mean a tape takeup problem in standard play, result in tape spilling out inside the machine. Sensors would catch this condition and go into a error mode, as yours is doing. One other thing which might be happening here, is the pinch roller not being disengaged from the capstan in the Rew/FFW modes. I think this is where I'd look first, and you can probably see if such is happening just by pulling the cover off the VCR. The pinch roller is just to the right of the rotating video head. In the play and forward/rev search modes it will press the tape up against the capstan (a rotating shaft). When in Rew/FFW, the pinch roller should be pulled back from the capstan, maybe 1/4 inch or so. Whatever the case, repair will likely take someone tech savvy. Costs might not be economically justified, with the low-cost, disposable rigs sold in the last 10+ years.
May 29, 2007 | Sanyo VWM-950 VHS VCR
Sony M2020 / M-2020 Microcassette Dictator and Transcriber Logo
499 people viewed this question
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
Paul
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
