No, at least I wouldn't recommend it.
Chip and Chipset are slang terms for I.C.
Integrated Circuit.
http://en.wikipedia.org/wiki/Integrated_circuitThe mounting of an audio chip uses a style of surface mount.
BGA.
Ball Grid Array.
http://en.wikipedia.org/wiki/Ball_Grid_ArrayReferring back to the older Processor's, they used pins on the bottom.
These pins mated up to socket holes in the processor socket.
With a BGA surface mount there are no pins.
Solder balls take the place of the pins.
The motherboard has matching copper pads for mating the solder balls.
The chip is set correctly in place on top of the copper pads, and the chip is then properly heated until the solder balls melt, and solder the chip to the copper pads.
It would be Much easier to just install a Sound Card.
The Sound Card can be installed in any available PCI or PCI-E x1 slot.
Gateway 506GR motherboard,
http://support.gateway.com/s//PC/R/3724/4367nv.shtmlClick on Components in the list.
On this page scroll down to the Motherboard heading, and click on -
102007 - Intel (Ausberg) No CPU Motherboard R0
Now click on - Specifications
To the right of the Add-n Cards heading we can see,
1) The motherboard has two PCI expansion slots. {Two PCI Conventional bus connectors)
These expansion slots are White in color.
2) One PCI-Express x1 slot.
(One PCI Express x1 bus add-in card connector)
View of Gateway Intel (Ausberg) motherboard used in a Gateway 506GR desktop computer,
http://www.ascendtech.us/itemdesc.asp?ic=mb4gwaugsburgScroll down towards the bottom of the page, and view the motherboard photo, and matching chart underneath.
Z1 points to the two long White PCI slots.
Z points to the shorter Black PCI-E x1 slot.
When the Sound Card is installed one of the expansion slot covers will have to be removed.
(Expansion slot area is shown as D in this rear view,
http://support.gateway.com/s/PC/R/3724/3724rv.shtml )
You may want to just use a Sound Card, that has basically the same specifications as the OnBoard audio you had before, (Integrated Audio), or you may wish to upgrade your sound system a bit with a better Sound Card, and be able to use satellite speakers, and a woofer.
To be continued in a Comment.
