I need the NVRAM tool for BizHub C250. Can anyone help. Thanx
You must have access to the a secure KonicaMinolta web site, need a tech to come out
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
SOURCE: bizhub c250 error code
There are 4 things to try to reset any error codes on these machines
1.) open and close front door
if that fails go to number 2
2.) open front door and turn off main power switch and then turn back on and close front door.
if that fails go to number 3
3.) turn machine off and then turn back on while holding down the utility/counter button after a while a trouble reset box will appear on the screen press on the box and then restart the machine.
If this fails go to number 4
4.) failing all this call your local service agent.
SOURCE: Duplex Printing
do you have duplex installed ? if you trying to copy duplex originals, you need duplex feeder.. in main displey the left tab is dupleks printing, if you have there options 1 -1; 2-1; 1-2; 2-2 then you have a duplex installed and you can copy/print duplex. also in driver menu there is a option duplex, wath you have to choose if you printing.
SOURCE: Bizhub C250 - Vista software
hello,
you have to install konica minolta c252 driver and software application. c252 adn c 250 are similar model.
You can download it (for windows vista) to konica minolta web site.
Bye
