At first hot water heater water was turning cold...my husband replaced the upper and lower heating elements...now the hot water is dangerously hot...whar could this be?
1) Make sure factory-supplied insulation and cover are reinstalled over thermostats, or cooler room temperature causes thermostat to under-approximate tank temperature, and this causes overly hot water.
http://waterheatertimer.org/images/Tank-with-insulation-2-600.jpg
2) Replace both thermostats.
Sticking thermostat can seem to act normally when tested, but when left alone it sticks, causing runaway overheating.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
More resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Testimonial: "thanks so much....still working on hot water heater....we will certainly give it a try..... we do appreciate it!!!!"
SOURCE: no hot water
If the water does not heat, then you have to troubleshoot to find the problem. With a voltmeter determine if 240VAC is actually getting to the water heater. Take care here - a defective circuit breaker can give a false 240 volt reading - check for the 240 volts across the upper element (i.e. when the 240 volts has a live load on it, not just an open circuit test).
Also, remember, the upper element has priority over the lower element, and if the water is cold, the upper element will try to turn on and this locks out the lower element (only one element is allowed to heat at any given time). The lower element comes on ONLY after the upper thermostat is satisfied. Therefore if the upper heating element is burned out you will never get any hot water. If you suspect this, TURN OFF THE POWER TO THE HEATER and take a resistance check of the upper element.
SOURCE: Electric Water Heater not heating water
Most likely it is not your thermostats. First check your circuit breakers in your electrical box. It should be a double 30 amp breaker. PLEASE USE CAUTION WHEN WORKING A ELECTRICITY! Next above your upper thermostat you will see a red reset button, push it and it should reset. It will take a little time for your water heater to heat again. If you keep having this problem it may be your elements!
SOURCE: warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
SOURCE: Which element?
turn off power then remove covers then check with ohm meter should have same reading on both elements but remove both wires from each element before you test
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for Electric Hot Water Heater
heatman101
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
If wire is bad between upper and lower parts of water heater, and water heater has tight-fitting 2" foam insulation, it usually indicates water heater replacement.
