Before I would be able to put a DVD in and the Mac would accept it, but it would just spit it back out without reading it. Now when I put a DVD in the Mac won't accept it at all. The DVD will go in but not all the way. I've tried the utilities but it didn't work. Any suggestions??
I think your mac's CD/DVD writer is damaged that is why it's not working. get to your nearest customer care. Only they can help you out.
https://crumbles.co/showbox-apk-download/
SOURCE: PowerBook Aluminum G4 1.67GHZ
Kim, I'm glad you asked this. I have had problems with my superdrive as well. What I found out through persistent research is this: The new Superdrives can take CD+R and DVD+R. (I am assuming you are asking about recording? However, the older models of Superdrives ---usually found in Powerbook G4s, can take CD-R and DVD-R. These are different from the first ones ini that they are slower to burn, and just a few gb short of space than the +. this should help solve the problem with taking new cds and dvds for burning. The superdrive tends to just spit these right back out. If you are referring to playing them, then have you tried cleaning the dirty ones? Check the help section at www.apple.com. they have wonderful solutions. Try to put in a couple new cds or dvds to play. Open up itunes or the dvd player before you put the disks in. If you're still having trouble, make use of that warranty and go to your nearest apple store to fix it right up! Hope this helps!
SOURCE: Macbook DVD drive
I wonder if the DVD is a faster disc than the Mac can handle. I know that when I use a 40x CD disc on a G5 optical drive, it's no go. But if I use a 4x disc, it's a happy camper. I bought an external drive to handle the faster discs.
SOURCE: my macbook doesn't burn dvd with iDVD program
Hello, this can happen when the DVD's are not recognized by your Macbook, please check in apple menu, about this mac, more info, and cd/dvd player to see what dvd can your mac accept
SOURCE: Mac Book Pro won't burn cds - spits out the cd
try a real music cd to check drive.
some blanks are no good try another brand or try a dvd to check drive
if it plays real and records on dvd then drive is ok
