My xperia x1 says it can not register on the network, I should end the data call and try again, but I have no active data calls. I cant get any service on the phone, no signal at all.
SOURCE: Repairing (replacement) Sony Ericsson XPERIA X1 LCD Display
All these videos below will help u in ur task
http://www.youtube.com/watch?v=pO2GSMb3aWM
http://www.youtube.com/watch?v=RHMKchQeOdQ
http://www.youtube.com/watch?v=V0sOaIo6724&feature=related
Pls RATE ME WELL !
SOURCE: pin code problem
JUST HOLD AND PRESS DOWN THE TWO SOFT BUTTONS AND PRESS THE POWER ON BUTTON ALSO.IT WILL TAKE YOU TO RESET MODE WITH WHITE SCREEN AND BLUISH IMPRINT.THEN CLICK R.THE PHONE WILL RESET.IT WILL DELETE ALL THE USER INFORMATION.SO TELL THE CUSTOMER B4 DOING THAT.
SOURCE: i have sony ericsson xperia x1, i have forget my
go to sony ericsson website then update your phone software but since you can not open your phone all data that were saved in your phone will be deleted but then your phone again.. it's up for you to choose.
SOURCE: i will like to change my xperia x1 phone language
Tap the windows start --> Settings --> System --> Regional Settings, on the Region tab, select your Language.
Hope this helps you. Please If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more.
SOURCE: X1 XPERIA LOCKED NOT SIM BUT PASSWORD
Do a hard reset on the phone and that will restore it to its factory default:
While the phone is off -hold down the front left and right buttons
on the X1 and insert your stylus into the soft reset hole all at
the same time.
After that you will see a blue screen says to press R to reset and delete all my existing stuff. Then you will have to calibrate the screen
www.usedcellphoneshop.com
