Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: I have a canon digital ixus 951s - some of the
You'll need to check your owner's manual for directions for turning that feature off. As for the pictures that already have the date on them, Photoshop Elements or any similar photo editing software can easily remove them. Also, if the date is near enough to the edge of the photo, you might be able to just crop it out.
SOURCE: I hve a canon ixus 8015 When I put photos from
Its a one way street...from camera to computer...not the other way around. Doing that will eventually corrupt the card and sometimes even the camera.
SOURCE: Taking the date off the pictures I take with my Canon Ixus 80 IS
Go to www.canonUSA.com, you can download the manual for the american version of the camera - the POWERSHOT SD 1100 IS
Instruction to turn on and off the date function are there.
SOURCE: I have a Canon Power
Every windows update changes the registry and sometimes causes our "toys" to stop being recognized. It happens to all of us. Pros avoid the problem by using card readers....you should too.
Testimonial: "Thank you very much for your help ! Best regards, George"
SOURCE: Hi, I have two new
Try NOT connecting your cameras to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
There are numerous solutions for importing digital pictures from your camera to your hard drive. You can use Windows Explorer. By doing this, u maintain complete control over where ur digital images are stored on the computer. If you prefer to use an external application, Google's Picasa remains the best solution available. In addition to being a convenient way to manage your images, Picasa also includes common photo editing functions, supports some of the best photo organization works with low level photo data from your camera, and assists in uploading images to the Web or creating slideshows on your local system. Picasa uses the timeline features that shows when images were taken in relation to all your other images (which only works if your digital camera is set to the correct date). Picasa is free for Windows 2000, Windows XP, and Linux.
