GTWN4250DWS top load washer The concrete part of a block they used for Weight purpose? came loose from its mount what a mess?
SOURCE: GE WASHER SPIN OUT PROBLEMS
Sounds like the suspension for the drum is having problems - there are usually springs holding the drum up and acting as shocks - one of the springs may have come off during an unbalanced load.
SOURCE: removing cover assembly on GE top load washer
Is your washer a GE Profile Harmony? Do you want to know how to take the top off or the top of the agitor (pulsator)? The top of the washer has four screws in the back top behind the screen once you unscrew them the front of the washer has two clips one on each side and you have to kinda tap it with your palm to get them to pop.
SOURCE: GE washer won't agitate
I had this same problem with our GE top load washer. I just needed to pull harder. (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.) Everything from the base below the large fins on up comes out together. Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out. I wasn't able to pull it out while it was still in the washer. BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself. I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator. Good luck!
SOURCE: GE top loading washer does not spin out water
The belt could be broken, if not. Unplug washer for 2 minutes, plug back in, open and close lid 7 times, this should reset electronic motor.
SOURCE: GE WBSR3140DW Top Load Washer Repair manual
Check your local Appliance Parts Stores, they usually have racks of repair manuals.
