Kodak Office Hero 6.1 All-in-One WiFi Printer Print, Copy, Scan, Fax Logo
David Stiffler Jr Posted on Oct 03, 2012
Brown background instead of white
When I print anything, I get a brown background and the lettering is a different color. If I was to print a letter, there would be lines of different colors and what should be black lettering, is also different colors. Please help!
Myron Reed
Level 1:
Habit-Forming:
New Friend:
  • Contributor 19 Answers
  • Posted on Oct 03, 2012
Myron Reed
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
19
Questions
Helped
2682
Points
54
You are probably out of ink in one or more cartridges. You need to do a diagnostic print and take the print to the ink supply vendor to get the correct replacements.
tip
Trailer Wiring Cheat Sheet
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, ground is white, +12vdc is black, etc), this is for you.
The following are the accepted standards for different trailer types.
The different plugs and connectors used are marked with either a number or letters. Having the functions of each in advance can save a lot of trial and error when troubleshooting..
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
Why won't my printer print purple?
Your Cannon printer is not the problem. You will get different print color depending on the paper you are using, For example you will get different print result if you print on color paper than on white paper and a different print if you print on photo paper. Another alternative is to lighten the tone of your purple. I don't know what your objective is and what project you're working on but I hope this might help.
Have a.o. smith SQ1152. Need config for 240 volt
Thank you for posting your question here on Fixya.com.
Depending on the age of the motor you should have a 'quick change' switch of some type you simply rearrange for the 240V setting. If not I assume you have an old motor with a brown and white wire from inside the stator positioned on posts L1 and B if memory serves correctly. White will be on the L post and Brown on one of the two lettered posts. Move brown to the other lettered post and put white where brown was if you have these leads.
If you do have a plug or rotary switch, reposition it for 240VAC and your done. In any of these settings you still leave your two incoming line leads, one each, on L1 and L2.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Printing white letters with black background..
you need to select the right tape for your machine. You can't change how it prints except by changing the tape. Brother has many colors to choose from.
I've tried to install a Honeywell 7500 thermostat. I believe I have it wired correctly. I have Red - R Yellow - Y Orange - O Blue - C Brown - X White - Aux
the colors aren't all that important.  make sure the letters on the thermostat and the letters on the furnace control board have the same wire connected.  that's all you need to do.
1helpful
HP 5740 Printer skips top half of several lines
try a letter with brown letters to see if it is the black ink cartridge Refilled cartridges do that from time to time
3answers
Lexmark black cartridge-and printer x1270 not printing black
I have a lexmark 6570 with similar problem. Who can help?
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
