Is there anything hanging down in the beam of the sensors? check sensor connections at the controller make sure there is no moister in it and are making good connections. is your water real hard a lot of minerals dirtying up the eyes. if all of this is clear and sensors are good then nothing else but the control board.
SOURCE: MV450 SCOTTSMAN ICE MACHINE
Personally I think the prices that you paid for the new TXV and dryer are VERY far out of line.Get what information you can off of the TXV power assembly and valve body along with the manufacturer of the valve and I will see what I can find out for you. If it is the power assembly that is rusted out and leaking there are kits for replacement parts on most valves.
SOURCE: scotsman 500 cm3 ice machine
Remove all molex connections and check for corrosion. Clean the connections and retry.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Scotsman Ice Maker CME 256
descale bin level sensors, check for corrsion on wire harness. if does nt work. replace . bin level sensors
SOURCE: Scotsman ice machine is not making ice. There is
The manual has an exploded parts diagram use as guide to locate parts.
First check the timer, you can manually turn it through a cycle or watch it rotate on its own.
Check the water inlet solenoid valve. if all looks well and you have definite water flow past the valve, then
Check spray pump. You have to remove the rear panel. The pump has a fan on the top. spin the fan if it is at all tight the ;pump is bad.
I have owned 2 of these units and have had failures of all of the above parts over the years.
