I had to bang the side of tv to make the picture appear what is wrong with it.
SOURCE: The sound on my sony KV-27s22 comes on realy good
You definitely have bad solder joint.If you have a soldering iron you may be able to fix it.The way your talking it sound like in the deflection area.remove the back cover and start the set then using something non conductive i.e a wooden salad spoon , knock lighly around the circuit that way you may be able to pinpoint the area where the trouble is. you`ll have to pull out the chassis to resolder the joints.look for rings around solder spot. good luck p.s; remove power before soldering
